Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 64 of 81 <123 ... 636465 ... 798081>
mk1collector
Got my mate who makes stickers to print me out a negative version of a cruise control sticker to put on the cruise on/off switch this week.
Stuck it on in place
Scratch off the paint in the gaps
And after removing the sticker I don’t think it looks too bad, not perfect but passable.
Got to get it all wired now Mr. Green Ray
My build thread
Post #714781 27th Jun 2018 5:01pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
That looks great👍 Which cruise control kit have you fitted? 2002 110 td5
Post #714830 27th Jun 2018 9:10pm
mk1collector
I’ve just bought the two disco switches and I’m going to wire it up myself..............................hopefully Confused Ray
My build thread
Post #714836 27th Jun 2018 9:15pm
Jimb1978
Understood...let us know how it works. Although I presume my 5th gear ratio would scupper it? 2002 110 td5
Post #714840 27th Jun 2018 9:18pm
mk1collector
Forgot to say, I bought a speedo healer too as I’ve got the 1:22 ratio transfer box in, speedo healer should work with yours if your planning on fitting cruise. Ray
My build thread
Post #714846 27th Jun 2018 9:22pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
JimB1978 - If it's a v8 ratio 5th gear then a speedo healer should sort it, it did with mine. Depending where you locate it in the loom, it will either alter the speedo reading and the CC limit together or just the CC.
Mk1collector - Are you mounting the D2 switch on the steering column? You will need to modify the steelwork behind a little but it is pretty simple. Likewise the base of the switch is flat whereas the column has an angle created by the upper and lower parts but a few minutes with a Dremel sorts it. Nice work on the CC switch Cool
 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #714918 28th Jun 2018 7:41am
mk1collector
Hi Harry, I’m fitting the column switch just like yours, I’d seen your pics before so was going to copy Embarassed Thumbs Up I’ve cut the cowl already but I still need to cut the metal bit. Ray
My build thread
Post #714936 28th Jun 2018 9:15am
Harry.O
Looking forward to seeing the finished result! Being honest, I copied the idea from someone else on this forum Embarassed 2005 Td5 110 Hardtop
Post #714956 28th Jun 2018 12:27pm
mk1collector
Finally piped up the provent so we’ll see how much oil it chucks out now Big Cry
 Ray
My build thread
Post #715065 28th Jun 2018 9:24pm
AJC
Harry, how did mount the D2 switch ? I’ve trimmed my cowl ready to fit but I have no idea how I’m going to line it up and fit it first and the get the cowl on.
Post #715078 28th Jun 2018 10:19pm
mk1collector
I was going to fit an L shape bracket to the bottom cowl and attach the switch to that then Slot the top cowl over the switch. Ray
My build thread
Post #715089 28th Jun 2018 11:21pm
mk1collector
Just a quick question, on the disco 2 switch, of the three wires in was the black wire the live in? Ray
My build thread
Post #715090 28th Jun 2018 11:24pm
Harry.O
Hi AJC, there's a few photos I posted in this thread if that helps. I fitted it to the bottom section of the cowl only, it seems pretty sturdy when the cowl is all bolted back together but it took a while to get it flush hence the washers under the bracket http://www.defender2.net/forum/topic58769-15.html
Mk1collector - Sorry but off the top of my head I can't remember which way around and I'm currently in the wrong continent to check the Defender. Do you have a multimeter that you can check with?
[/quote] 2005 Td5 110 Hardtop
Post #715098 29th Jun 2018 7:07am
AJC
Thanks Harry, that's great. My job for tomorrow afternoon
Post #715104 29th Jun 2018 7:25am
Nice job on the cruise control Ray Cool
Post #715106 29th Jun 2018 7:29am
