Home > Td5 > New to me TD5, but seems down on power. |
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 |
Hi Roel,
Many thanks for all your great feedback. The tuning chip fitted to our vehicle is a Dastek Unichip. It has the piggy pack take off loom, and the existing rover ecu is mounted up high behind the drivers seat. We did have some oil in the loom, but this was only at Rhe connection to the piggy back, not at Rhe ecu end. We have cleaned all of the ecu extension loom connectors of oil using brake cleaner, they are all clean and uncontaminated now. Yes we k ow the Fedima tyres are big and heavy, but all four of them were fitted brand new before collecting the vehicle, so they will get used and changed later to a better quality tyre when they have worn out. Later today we will try reconnecting the ecu back to the normal position, to see if it gets rid of the hiccups or makes it run any better. Cheers. |
6th Jun 2018 10:12am |
I see you’ve cleaned oil from the ecu plugs but have you put a new injector loom in? Ray
6th Jun 2018 1:30pm |
Hi Ray,
No we haven’t done that yet, it’s on the shopping and to do list though. Thanks for the reminder! 👍👍 |
6th Jun 2018 2:09pm |
So another quick update, we today reconnected the ecu back to the std loom connectors.
Success! The misfire and hesitation has gone. So started to undo all the tywraps to get the extension looms out with a view to removing the Dastek chip boxes and looms. Then I found this on the two block connectors going into the Dastek ecu. Somebody has done a proper bodge, but most importantly two wires were completely hanging out. After about an hour of trying to remove the pins to re do them, I gave up, for fear of damaging the plastic block. I resorted to stripping and tinning the wires, and reinstalled them in the block,and pinched the cable clamp part of the clip back over. They have a nice firm mechanical and strong connection now. Gave me the car a road test, and my god what a transformation! I can only assume that the two wires that were hanging out had meant the Dastek ecu was not working properly. The car now has massive low down pulling power. The run we had for a few miles also revealed that the jumping misfire has gone too. So for now as the Dastek seems to be doing it’s job, will leave it connected with the ecu nice and high up out of the way of water when wading and keeping the ecu clean of any oil that might come back. Thanks to everyone who gave us some many great tips and pointers! Here’s the connectors with the wires hanging out! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
6th Jun 2018 2:18pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1571 |
See I told you so
6th Jun 2018 6:35pm |
Agreed Nick!
Although it was more like this though! Click image to enlarge |
6th Jun 2018 8:47pm |
Have the same one Port-a-sol, made in Ireland - three times the price from snap-on, wish I knew that before I bought mine!
6th Jun 2018 9:07pm |
