Home > Td5 > More heat needed |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10364 |
I'm going to be positive about the Puma.... I had the window open on the way in today..heater speed 1 and I was boiling
The td5's heater is woeful. |
28th Feb 2018 12:42pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Thanks that helps.....
Can a Puma heater be fitted to a TD5? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
28th Feb 2018 12:57pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4946 |
get some of graftys vents Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
28th Feb 2018 1:14pm |
I have some - and they are ace. But need more heat! 1999 Defender TD5 110
28th Feb 2018 1:17pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
I have the issue that my new heater matrix is so efficient that it just cools the TD5 engine back down again in cool weather! 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
28th Feb 2018 1:19pm |
What matrix do you have? 1999 Defender TD5 110
28th Feb 2018 1:21pm |
just a new OE one 02' 110 TD5 Double Cab Rebuild Thread
28th Feb 2018 1:24pm |
Worth the effort? Did you swap because of lack of heat? 1999 Defender TD5 110
28th Feb 2018 1:25pm |
I actually swapped it out because of a coolant leak from the end of my old matrix, however the new one (along with replacing the foam insulation within the heater box) is much more efficient that the old one (which wasnt visibly corroded or blocked that i know of). Trouble is you have to hold off turning the fan up until the engine has warmed up fully in cold weather or it cools the engine back down.
I did see an Alisport uprated heater matrix however. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
28th Feb 2018 1:30pm |
Cheers for the info Steve. I might have a look into the matrix side of things.
I don't have Alisport money. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
28th Feb 2018 1:36pm |
Part of the issue is the lower part of the dash is basically the whole of the piping before it gets to the piddly little vents.
Even a brand new matrix isn't great (have one on the V8 ) and they are a lot warmer running than the td5! Maybe a diesel heater like Eberspacher? |
28th Feb 2018 3:40pm |
Woeful? Poppycock... It is adequate when dressed correctly... Besides, follow these simple rules for dress code and you'll make it through to Spring; Click image to enlarge |
28th Feb 2018 4:20pm |
Unfortunately not. |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
Rad muff might work
28th Feb 2018 4:21pm |
