Home > Puma (Tdci) > 2.4 2007 Rough idle worse in cold weather |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2603 |
looks like the OP has the same issues as I, see the history here: http://www.defender2.net/forum/topic50069.html --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
21st Sep 2017 8:46am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19643 |
It isn't urgently required but the idea of the blank is mainly a safeguard just in case the EGR leaks or is partically stuck open.
That is difficult to determine and won't always flag DTC's or illuminate the MIL. Having said that, the probability is highly unlikely! But seeing as I did actually have EGR issues, I wanted peace of mind and it is very easy to just slip the plate in. You don't have to fully remove the bolts or gaskets, simply slip it in on the inlet side. And tighten to Torque specified. https://www.defender2.net/gallery/albums/u...4l%20D.pdf ^^^^ WSM Section Ref EGR. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
21st Sep 2017 1:25pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16927 |
I agree it is not a bad idea, and gives peace of mind.
21st Sep 2017 4:57pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7706 |
i have run a 2.4 with software EGR off since 67k miles, with no blank.
On this one i went for the Alive EGR off option (software) and fitted the blank - thank you for all advice on here, took 10mins or so and its tight but not too bad, no where as bad as its made out to be! More importantly - no more rough idle since EGR off function! (although need a colder morning to be extra sure!) Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
29th Sep 2017 2:57pm |
