Home > Puma (Tdci) > 2.4 2007 Rough idle worse in cold weather |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 427 |
Have you tried reading any codes? I'm certainly no expert but I'd not be surprised if you had a glowplug issue.
14th Sep 2017 4:19pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7695 |
no, working on that. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
14th Sep 2017 7:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19607 |
Try this, it should at least clean everything through.
http://www.opieoils.co.uk/p-60222-millers-...tment.aspx Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Sep 2017 7:30pm |
ok, will do, whats the thoughts on adding 2 stroke to it for same effect? Cheers
14th Sep 2017 8:03pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I don't know a way you visually check those valves. On mine, a diagnostic tool shows the fuel pressure fluctuating wildly. I have the same problem, suspect the VCV, but as it doesn't do it when it's warm it's not bothered me for a few months. I'll now doubt be contemplating changing the VCV again in a few weeks. 2007 110 TDCi Station Wagon XS
14th Sep 2017 8:05pm |
Bluest, so yours has exactly the same symptoms? Cheers
14th Sep 2017 8:11pm |
I have lumpy fluctuating idle in winter when the engine is cold. It occasionally happens when warmed up, but to a lesser degree. Virtually never happens in warmer weather, if it does it is much less severe. Using Millers Dieselmax additive seems to alleviate the problem a little.
My theory, and it is only my theory, is that the piston in the VCV gets dirty or corroded and starts to get sticky. For some reason temperature and/or the extra lubricating properties of the additive alleviate it to some extent. I have a new vcv to go on but I haven't done it because just because I haven't got the tool needed to programme a new one, I forget how annoying it is and I've been busy. 2007 110 TDCi Station Wagon XS |
14th Sep 2017 8:22pm |
I had similar last winter also but haven't seen it as much to worry about.
Again likely the VCV but the programming is a pain in the backside so I see that point of view.. I think it's likely that in the winter the diesel waxes more and everything inc as suggested above the VCV workings become more sticky. Diesel also has different additives in the winter I believe due to possible freezing temperatures. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Sep 2017 8:33pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 530 |
Same issue here...
I've been considering changing the VCV as well, now that the Nanocom (version 1.33) has support for "pump learning" for the Puma 2.4 (< 2012). Has anybody used these (new) features in Nanocom, pump and injector pilot correction learning? (injector pilot correction learning was added a while ago whereas the pump learning is a brand new feature in Nanocom software v1.33) “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
15th Sep 2017 8:18am |
That's grabbed my attention! I have a Nanocom. How did you find out and how do I upgrade mine? 2007 110 TDCi Station Wagon XS
15th Sep 2017 8:54am |
I've found out in the release notes for the new version, I've been waiting for ages for this feature to be added
The Nanocom forum also has some discussion about that feature and where it was added (was not obvious at first in which menu entry it was to be found...) Nanocom forum is here: http://forum.nanocom-diagnostics.com/ You can get the SW update from the restricted area: https://www.nanocom-diagnostics.com/restricted Additional information (and how to upgrade) can be found either on their forum or in the documentation (including videos) “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
15th Sep 2017 9:01am |
Thank you, I'll check that out tonight. 2007 110 TDCi Station Wagon XS
15th Sep 2017 9:38am |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 105 |
Change the vcv, THEN do the pump re-learn & injector pilot correction. This will most likely solve the rough idle, if your glow plugs aren't working well it will rough idle for 10 seconds odd after starting cold and then should pick up as normal.
I have the BAS2 RRC tool and can do the pump learn and injector correction in a matter of minutes from my iPhone. My very quick review of the vcv change.. http://www.defender2.net/forum/topic55914.html Last edited by M94PUMA on 15th Sep 2017 7:36pm. Edited 5 times in total |
15th Sep 2017 7:26pm |
looks like i may be on the scrounge for a nanocom then! Cheers
15th Sep 2017 7:27pm |
