![]() | Home > Puma (Tdci) > Black smoke and gas pedal delay |
Vesku Member Since: 12 Jul 2016 Location: Paimio Posts: 44 ![]() ![]() ![]() |
Ok.
Don't know the fault code number but LR service found that ECU box is broken. They will try an new ECU some day soon I hope. And no smoke when egr connector unplugged. |
Can this cause my problem?
https://goo.gl/photos/TpsKdiBXM2mD57rF8 |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 453 ![]() ![]() ![]() |
Hi again,
Have a look at this topic I just posted.... |
I'm going to remap on monday. Bye bye EGR..
Hope that will finally solve my problems. |
Let us know how you get on. I'm starting to think that my problem is possibly based around the ECU. If the local dealership ever give it back I might be able to investigate a bit more
So I have remapped my car and EGR is taken off
Engine runs well but still there is a visible black smoke sometimes when accelerating 4 and 5th gear. I'll put planking plate on thursday so let see what happens then. |
And there was a hole in hose!
Just ordered siliconehoses and a bigger cooler😀 |
Petrovich Member Since: 24 Jan 2008 Location: Sankt-Peterburg Posts: 75 ![]() ![]() |
Vesku - your are the lucky one!
My 110 still rattling and black smoking when accelerate After MAF changed, EGR and gaskets revised, turbine's hose pipes inspected Officials says that turbine need to be changed or restored. But ! Oil level still stays normal and that why I'm confused Cos if turbine makes problem - oil level should be lowering (I've been told) ... Defender 110 '07 |
Local LR service checked intercooler/turbohoses but they could not find any damage there.
So I checked those pipes again and there it was. A 3cm long cut on cooler pipe. Ordered silicone ones and a Serck cooler and now my defender flies! |
Gotcha !
Did your turbine was rattling when you accelerate on the road as well ? Defender 110 '07 |
