Home > Technical > ATB (torsen) front and rear install
Page 11 of 23 <123 ... 101112 ... 212223>
Naks
ordered an Ashcroft ATB for the rear diff. Can't wait to install and go play Thumbs Up --
Post #623339 11th May 2017 9:07am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
KAM...
KAM seems to offer a combination LSD and diff lock in one diff - with locker selectable when necessary. But never read about it in practice yet:
Post #623782 13th May 2017 7:00am
LR90XS2011
think that needs a lot of mods to the axle casing DEFENDER 90 TDCI XS,
Post #623790 13th May 2017 7:45am
Timo K
Finland
It's also a clutch pack type LSD instead of the gear driven variant.
Post #623818 13th May 2017 10:42am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Hi,
Been told that the ATBs don't react well to big tyres.
Anyone has feedback on how well they work with let's say 35" tyres?
Post #624000 14th May 2017 10:30am
They work exceedingly well with 255/85 x 16 tyres.
Post #624214 14th May 2017 10:51pm
Arierep
That's the size I have right now.
I'm considering to order an ATB this week for the rear, then if I like it maybe get one for the front also.
I might go for 315/75R16 in the future, want to be sure the ATB diffs keep the job with that
Post #624215 14th May 2017 10:58pm
Naks
Look at what arrived this weekend, can't wait until it's installed!
Post #630677 12th Jun 2017 8:56am
Naks
is the P38 spacer ring necessary when installing in a Puma rear diff? Question --
Post #630769 12th Jun 2017 2:42pm
MK
If yours is a 90" then you do not need the spacer. Puma 110" SW
Post #630774 12th Jun 2017 3:15pm
LR90XS2011
well finally got round to fitting one of my Ashcroft ATBs into my rear axle.
Swapped the crown wheel over from the standard diff adjusted the bearings per the manual, all went well and completed on the drive in just over 3 hrs start to finish.
Most difficult bits were getting the back lash right (you need a DTI) and holding the diff when you torque up the crown wheel bolts and bearing carrier bolts as I only have a 1 ton vice it was only just big enough. otherwise a rewarding job.
found that one of the drive shaft flanges was starting to fret (rust dust in the cap) , the other appeared to be locktited on!! I thought 90s had 1 piece shafts! so knocked them both off (yes they were very tight) cleaned the splines greased and refitted.
Only driven 30 miles or so but no noticeable difference on the road, once I have about 500 miles on it if its OK will have a go at the front.
PS the diff that came out looks in A1 condition only 20k miles and no abuse DEFENDER 90 TDCI XS,
Post #642427 7th Aug 2017 6:18pm
Caterham
Hi,
Did you need a spacer between the crown wheel and atb or in lieu of that have you adjusted the bearings?
Any photo to compliment the work Thumbs Up
Post #642445 7th Aug 2017 7:14pm
LR90XS2011
Being a 90 its a straight swap and the bearings on the carrier are adjusted to set the backlash and become pre-loaded in the process. (Used new carrier bearings)
Didn't need to touch the pinion bearings as used the original carrier and crown wheel so everything ends up in the same position give or take a few 0.01mm's
everything you need is describes on Ashcrofts web site DEFENDER 90 TDCI XS,
Post #642457 7th Aug 2017 8:09pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
So, if your only replacing the centre of the diff with the ATB and leaving all the other parts the same, it's just mesh and backlash/prelod you need to worry about?
I'm thinking of building these into my diffs but the only guides I can find are full rebuilds rather than just the centre of the diff being swapped.
I have only done 20k miles so don't think it's worth stripping the lot and a full rebuild. (Thoughts)
Post #646406 26th Aug 2017 11:51am
Correct.
Post #646411 26th Aug 2017 12:28pm
