Home > Maintenance & Modifications > Fuel/money saving remap.
Page 2 of 3 <123>
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
camelman wrote:
I have the BAS 170 remap and have seen no change in mpg (either way) after 15,000 miles.
That's interesting. I usually get 26 - 27 mpg using the truck for work. Some towing. All lane driving.
I'll work out mpg once I've got the new map and report back. 2009 2.4TDCi XS Utility Wagon.
Post #620777 1st May 2017 4:36pm
JOW240725
I've never dared calculating mpg before or after but after is SO much better it was definitely worth it! James
Instagram @suffolk_rovers
Post #620796 1st May 2017 5:44pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
I track mine with Fuelly.com
I find it was an easy way to spot when the Disco was feeling rough or wanted an oil change.
Post #620797 1st May 2017 5:47pm
ChrisWoods
Well now the map is installed I will have a definitive answer. Previously my average was 27mpg.
Update in a month. 2009 2.4TDCi XS Utility Wagon.
Post #621984 5th May 2017 8:10pm
ChrisWoods
Well first tank of fuel. 23mpg but that's with about 100miles of towing 2.5tonne, a few evenings out in the fields shooting and a short 100mph spat to make sure the speed limiter had been removed. I'm hopeful for my 2nd tank as my driving is back to normal after testing the map.
It goes like a stabbed rat. 2009 2.4TDCi XS Utility Wagon.
Post #624476 15th May 2017 10:22pm
Likeomg
Install cruise control....
Normally i get 250 miles max / tank my last tank i got over 280... main difference is i installed cruise recently and been using it a lot.
Thats a alive PP4, roof rack, Shell v power..
Post #624485 15th May 2017 10:50pm
Naks
I got a BAS remap on my Puma in 2011 (1 year into ownership). It paid itself in fuel savings within the first 2 years Thumbs Up --
Post #624538 16th May 2017 8:39am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I have the BAS remap on my 2.4, I also use the Roadtrip App to record fuel usage. When I first got the 90 I was averaging 26/27 mpg using Shell V Power, after the remap I consistently average 29/30 mpg using the same fuel.
Post #624552 16th May 2017 9:53am
camelman
Over 15k miles I've averaged 23.5 mpg in the 110 since the remap.
The best tank it's done in that time is 24.5 mpg and the worst is 22.
Most of that is on the motorway however which is what keeps the mpg down,
Post #624556 16th May 2017 10:15am
JOW240725
Rolling with laughter Rolling with laughter
Which map did you go for in the end?
Likeomg wrote:
Install cruise control.....
Good call. With a remap it's all too easy and comfortable to go too fast, which drinks the fuel. James
Post #624585 16th May 2017 12:46pm
jst
my own experience with td5 was first 40k miles around 26mpg mixed, next 60k miles 29mpg with remap. but then that could of been the running in toooo!
had a VW that did std 36mpg, after remap did 45mpg on same 1000mile weekly commute so comparable over 50k miles.
muy experience with Puma is better mpg once mapped unless you use the extra grunt, like towing when i typically saw lower mpg with remap than towing without remap.
Something else to ponder, as elduded to. transfer box is 1.2std on Puma, fit a 1.4 if you want better pick up (but will give more revs at cruising.
I have a 2007 std tune with a 1.4 t box on 33" tyres. it does tows better than my 2.4, 1.2 remapped on 31" tyres. and uses less fuel towing or not. GPS miles on both. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #624594 16th May 2017 1:06pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Defender TD5
Dynachip Stage 1 - MPG went from 23ish to 25ish
TD5inside Stage 2 - MPG went from 25ish to 29ish on a good week
These are obviously after the initial week or so when you're putting your foot down a bit...
Discovery 3
BAS 'stage 1' remap - MPG actually went down from 26ish to 23ish MPG Sad That backfired but huge difference in responsiveness (wouldn't change it).
I use an app to log mileage so can verify all on both vehicles (only TD5 below).
 TD5 Defender 90
Discovery 3 HSE
Post #624618 16th May 2017 2:44pm
ChrisWoods
I'm not sure, thought there was only one BAS map for the 2.4. Think its the 165bhp and 440Nm.
The engine is sweet but when using the extra torque it highlights my drivetrains issues. Gotta get them sorted this summer. 2009 2.4TDCi XS Utility Wagon.
Post #624912 17th May 2017 6:54pm
yostumpy
Last fill up on my 300tdi 110 HT, was at 340 miles, and got 32.3mpg on fuelly.not back at 170 k and 19 years old
Post #625525 20th May 2017 7:08am
ChrisWoods
As my right foot gets lighter my average mpg is going up. Back to 26mpg now and that's with me still using most of the grunt and occasionally driving like I stole it on a quite A road. BAS Intercooler next so see what difference that makes. 2009 2.4TDCi XS Utility Wagon.
Post #648905 7th Sep 2017 10:33pm
Page 2 of 3 <123>
