Home > Td5 > 2003 TD5 Coolant System over pressurising |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4406 |
Oh no that's no good mate silver lining is A1 head from now on Turner are a good company used them a couple of times.
You going to hone your cylinders, mod the exhaust manifold or anything else whilst the head is off? |
30th Mar 2017 8:41pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
I'm considering de-webbing the exhaust manifold. Looking into upgraded manifold bolts, just starting to search around for information on them. Anyone with info, please feel free to chime in.
In regards to the de-webbing, I know some have completely removed the webbing between the ports, some have just made a relief cut in the webbing between ports. Anyone have any experience? Pass it along.... Oh, I do have a stage 1 Alive chipped ECU I am wanting to install, figured there's no point until the new head is on. it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
2nd Apr 2017 7:05am |
OK... found it!! Head gasket failure, front of #1.
Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
5th Apr 2017 5:25am |
I still think I am going to have to replace the head on Miffy (not he funky white rabbit) as I am getting over pressurising still post installation of a new water pump. Before going there though I have to replace the threaded core/drain plug as it is possible that it might be the cause, letting air in to the system. Possible I guess.
If it makes you feel any better CDN38 I will also have to whip off the exhaust manifold again. LR really should have installed a quick release mechanism for this manifold, would make our lives much easier. |
5th Apr 2017 7:03am |
Funny you mention that I have just replaced a couple just last weekend! Cap replaced at the same time. Ach the joys of owning an aging vehicle...!
5th Apr 2017 8:37am |
Well just picked up this little beauty...
Click image to enlarge Figure it should work with the LRs VDO sender unit... give it a go... a little mid week modding this evening I feel. |
5th Apr 2017 8:40am |
bifterx Member Since: 29 Nov 2014 Location: North Wiltshire Posts: 33 |
I may have also been sucked into this sad tale.
Top hose burst/split a couple weeks ago, replaced it with silicone jobby. snapped the expansion tank plastic pipe in the process so swapped new in for that as well. Im now getting leaks/drips from (as far as I can see ) the bottom of the rad at either side when system is pressurised. not sure if the rad should look like this .... Click image to enlarge all bendy at the bottom. this is either a series of unfortunate coincidences or something darker! I had a new head and gasket etc done in august last year as it was cracked. its a 4A VIN so guessing it would have had steel dowels anyway? Temp gauge is always left of centre when up to temp and has been since I've had the vehicle so no change. No blow offs from exp chamber, just the usual hiss on engine stop. I was sort of in denial re HGF 7 or 8 months after new head but now rethinking. Also yesterday took for a run and had power loss /hiccup for a fraction of a second on dual carriageway doing about 55-60 before resuming but no flicker in the temp gauge. Disco 300TDi XS - Gone Disco 3 SE manual - Gone 😭 Freelander 2 SE manual Defender 110 TD5 DC |
11th Apr 2017 11:38am |
oh yeah!
deffo new rad then. http://www.defender2.net/forum/topic50978.html um, anyone got any tips loosening the viscous fan nut? cant move the still, coincidence re top hose and rad in the same 2 weeks. Disco 300TDi XS - Gone Disco 3 SE manual - Gone 😭 Freelander 2 SE manual Defender 110 TD5 DC |
11th Apr 2017 11:57am |
Crikey Bifterx How the heck did your rad do that?!
Have you replaced your water pump recently? Apparently when long in the tooth these can sieze when hot causeing over-pressurization of the coolant system. I replaced mine last month along with the PAS pump as the dog gear was well worn, indicating something not running true. Also check that damned coolant drain plug under the exhaust manifold. 4A VIN should be metal dowels, plud if your head was replaced last august it should of had them replaced at the same time. Viscous fan nut. Have you the correct spanners? are you turning the nut the right way? TD5s have a normal right hand thread. |
11th Apr 2017 12:18pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2552 |
Do you have a source for the gauge? Or a VDO part number? Looks a good match for the standard Td5 gauge set in terms of appearance. |
11th Apr 2017 12:47pm |
My thought exactly Retro...
Part numer 310.284/8/3 12v and photos; Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
11th Apr 2017 1:44pm |
So new rad- not really digging the moulded look.
I saw your thing on the water pump - my PAS pump is due for a replacement as its got a slight leak in the castin, it scraped through MOT cos it is slight so its on my list for things to do may as well do WP at the same time, I dont think its an expensive part. yeah got the right spanner although this is the first time I've used it in anger - just cant seem to get enough leverage. coolant plug all good. cheers rob Disco 300TDi XS - Gone Disco 3 SE manual - Gone 😭 Freelander 2 SE manual Defender 110 TD5 DC |
11th Apr 2017 2:31pm |
Two bits of scaff pole on the end and gently does it.
11th Apr 2017 2:41pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 719 |
Buy the best water pump you can afford. There are some pretty rubbishy ones out there which are cheap, but don't last two minutes.
11th Apr 2017 3:43pm |
