Home > Td5 > Leaky Radiator
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Leaky Radiator
Walked up to the parked 90 the other day I noticed its been marking its territory (awwwww). Dog
Having just driven 200 miles it seems to have leaked out and around the radiator... area (it was quite dark). It was quite a cold (-3) road trip from Dundee to the lakes so i thinking the cold air might have helped keep things cool. Shame Scotland is renown for it long hot summers!
After checking the expansion tank its definitely dropped but not considerably. Doesn't seem to leak when its cold, so I'm thinking it may be down to pressure. Question
Other than ripping it all apart any pointers to fault finding?
What pressure does the radiator system work at normally (when its all hot and running)? Worth getting a pressure gauge or a pump to test it? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #583257 7th Dec 2016 5:10pm
dorsetsmith
below 1.4 bar or 20 PSI witch is open pressure for the cap
Post #583259 7th Dec 2016 5:18pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
if it helps. mine had a leak from the plastic end cap on the rad. I've heard of others doing good it too 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #583355 7th Dec 2016 10:46pm
bogwert
Cheers Dorsetsmith!
Good shout gazman, ill see if i can pressurise the system and check where its coming out! Chris
Post #583869 10th Dec 2016 3:58pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Fellow dundonian Thumbs Up
Mine was the complete opposite. Only leaked when cold, could see it tracking down the road fins, onto the crossmember and dripping onto the ground
Oddly, it never got close to overheating either
Cheap enough to repair though Thumbs Up
Post #583894 10th Dec 2016 6:54pm
Alien
Australia
Have a look for stains at the fuel cooler before starting it up.
The O rings only leak when it's cold and coolant could be migrating down the hose towards the radiator when stationary.
Cheers, Kyle. Cheers,
Kyle.
Post #583995 11th Dec 2016 12:12am
bogwert
So drove it out to the back of Dundee (15 mile trip). Bone dry when I arrived, left it to cool and the drips appeared.
Might be on the same lines at Mikey's.
I'll bring it round in the new year Mikey! Very Happy
Alien, seems dry before starting it up but will keep an eye on it! Thumbs Up Chris
Post #584077 11th Dec 2016 12:47pm
Disco_Mikey
I look forward to it Thumbs Up
Post #584312 11th Dec 2016 11:05pm
bogwert
Due to lack of time and daylight in the week, ended up taking it to Disco_Mikey at MMP, Dundee.
Turns out the radiator was Censored, to say the least. what looked like a few missing fins, behind was a ruined radiator bowed and leaky!
Thanks to Mike though who had it diagnosed and turned around with a new shiny one within 2 days! Excellent work, thanks mate! Thumbs Up
 Chris
Post #596108 25th Jan 2017 10:45am
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Looks very similar to mine which I changed before Christmas.
All the fins had corroded at the bottom and the lower edge was bowed.
Mine wasn't leaking but it wouldn't have been long.
 Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #596315 26th Jan 2017 12:41am
