Home > Puma (Tdci) > oil pump failure 2012 2.2 TDCi |
Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85 |
My Defender went in to the local LR dealer, in Droitwich and all the outstanding recalls were carried out or confirmed as done. All sorted, no cost.
8th Mar 2017 4:32pm |
Ecco Member Since: 31 Oct 2015 Location: Kuala Lumpur Posts: 279 |
..is this issue related only to MY2012 ??
9th Mar 2017 6:11am |
Ecco
As I understand, it's over a range of engine/VIN numbers, mostly in 2012. Your best bet is to register with the Topix website and do a VIN search on your vehicle, then check for recall service actions. Regards David |
9th Mar 2017 10:07am |
CRC@LandRover Verified Account Member Since: 25 Mar 2013 Location: Coventry Posts: 383 |
Good morning Ecco, Thank you for your message. I would be more than happy to investigate this further for you in order to confirm what recalls are outstanding. In order for me to do so, can you please kindly confirm your vehicle and contact details. Many thanks, Amellia |
9th Mar 2017 10:12am |
Hi Amellia
Now that my vehicle is "up to date" with the recalls, who updates the Topix website? It still shows my vehicle as needing the recalls. Regards David |
9th Mar 2017 10:16am |
Good morning Farmer58za,
Thank you for your message. I can confirm that this is updated internally once the recall has been completed and reacts to information submitted by an alternate system. Just for future reference, there will be a record to state that this has been completed on an alternate system so on your next retailer visit so this is not actioned further, however there may have been a delay in TOPIx updating. Many thanks, Amellia |
9th Mar 2017 10:22am |
ian4002000 Member Since: 07 Jun 2014 Location: Bittern Posts: 3 |
Things must happen faster in Australia !
My 130 had the oil pump recall and fix late 2015 or early 2016. I had the second recall on getting the front axle extra bracket added around Feb 2016. Did you get the front axle recall in England ? Ian Bittern Australia |
26th Apr 2017 10:40am |
cmcc Member Since: 08 Jun 2017 Location: Derry Posts: 2 |
My defender with full service history registered 2014 oil pump failed last week and wrecked the engine and its one month out off warrenty
I think I need to check the vin number to see if its on the list were it should have had the recall done! I'm waiting on Landrover to reply about it, a weeks gone by and nothing yet Cathal. |
8th Jun 2017 11:58am |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 |
Does anyone know the vin range for this recall?
Cheers Dobbs |
8th Jun 2017 12:19pm |
http://www.defender2.net/forum/topic34986....p;start=15
My Defender is about 8000 vehicle's from this recall, I'm wondering is there a wider problem outside this vin number range? Cathal. |
8th Jun 2017 1:57pm |
Thanks cmcc.
So there's post in that thread which says "The Service Action has the Vin Range: LD405037 - LD443988 and is listed for Model Years: 2012 - 2013" Does that mean the actual VIN needs to end on ...LD123456 or the "LD" simply means Land Rover Defender. My VIN would be in that range, but the "LD" are two other letters. Surely LD Vins are 1990's VINs? |
8th Jun 2017 4:56pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6484 |
LR tech bulletins use a (non obvious) combination of the vehicle model ID (LD = Defender, LA = D3/4, LR = D5 etc) and the last 6 numbers of the VIN (sequential build number).
So check your last 6 numbers rather than any letters. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
8th Jun 2017 5:17pm |
Thanks Martin,that's what I thought.
I'm in the middle of the VIN range, but oddly my stealer tells me I'm not affected. |
8th Jun 2017 7:05pm |
Beyond Repair Member Since: 12 Jun 2017 Location: NI Posts: 1 |
Hi Harry. I'm having a similar problem - how did this work out for you? J |
12th Jun 2017 2:49pm |
