Home > Maintenance & Modifications > Dirt Defenders |
Yes and yes Ray
4th Feb 2017 10:20pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 907 |
Ditto and Ditto
4th Feb 2017 10:36pm |
robtd590 Member Since: 28 Dec 2016 Location: Somerset Posts: 26 |
Cheers Ray,
Do you find that mud/road grit collects between them and under sill? Or do they fit as a tight seal as I have chequer/tread plate sills fitted. Cheers |
Cheers Devon Rover
4th Feb 2017 10:44pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Excellent bit of kit, fitted them to my HT90 and the wifes XS 90. On my had to plasma cut the chequer to get a neat fit, on the wifes with genuine landrover chequer being thinner didnt need to cut it. Certainly keeps dirt of the door handles. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
4th Feb 2017 10:49pm |
Cheers for the info
Do you have them fitted front and back? |
4th Feb 2017 11:03pm |
Yes on both 90s. Mine are painted, left the wifes unpainted 2015 HT XS 90
4th Feb 2017 11:13pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1333 |
I have them and they make amassive difference
4th Feb 2017 11:20pm |
I have front and back on my 110 with chequer on rear quarter but none on the sill and with the provided strip of adhesive backed foam fitted no dirt or grit gets through in between the panel and the dd. Ray
5th Feb 2017 12:39am |
There is a few threads on here if you do a bit of mining with the search function.
I fitted them to stop the amount of muck being thrown up the rear quarters by the tyres and they do a fine job. I was nervous about the drilling into my prized baby but the results are worth it. Click image to enlarge |
5th Feb 2017 1:33am |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
If you fit them all - there are 6 of them: back of the front wheels, front and back of the rear wheels. Simple design - but works well. My tyres are OEM Wrangler MT 235/85/16 - after adding Terrafirma 30mm spacers the dirt D-Fenders still work well. 255/85/16's may cause some dirt to cling to body work again?
5th Feb 2017 6:13am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Yes i only fitted them to the back of the rear wheels and they do a good job As i have jackable sills i find they do a great job of keeping the mud and dirt off the side from the front wheels 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
5th Feb 2017 10:30pm |
jk84 Member Since: 17 Feb 2015 Location: Wherever my Defender takes me... Posts: 720 |
Have bought a pair of DD-fenders for both front and back and wondering if any of you gents used self tapping screws or if you all riveted these on? Haven't got a rivet gun but if that's the preferred method I better get one! MY15 Aintree 110 SW - for sale - https://www.defender2.net/forum/topic82781.html
MY16 Santorini 90 HT - sold |
23rd Feb 2017 6:32pm |
I can't see why not to use small self tappers.. If you were closer Jaro I would lend you a rivet gun.
23rd Feb 2017 6:39pm |
