Home > Puma (Tdci) > Fixing diesel knocking at home.. Possible? |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 |
Darn mobile - somehow, the gallery does not work - but here's the promised image
Gentlemen, do you see anything unusual in this picture? https://drive.google.com/open?id=0B3n-BiaGvPMxV19oZUFpa2Naajg |
5th Jan 2017 2:23pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
An extra washer on one?
£850 to change them and they can't count up to 2? Or am I mistaken? |
5th Jan 2017 3:03pm |
You are exactly right. 850 quid for bad counting
5th Jan 2017 3:18pm |
Frick.
Such a fundamental oversight. I would not be pleased were I in your position. |
5th Jan 2017 3:28pm |
Yes, I'm rather angry at them and will check legal remedies today ...Agentmulder, how did your operation unfold?
6th Jan 2017 5:57am |
No operation yet...
I don't know what I don't know about it, so I'm scared I'll open something that will require special tools to get it back together. I have however ordered a new VCV valve though, cheap enough to try, and with the BAS RR2 tool I can do pump learn and so on. I was reading up on them and how a faulty VCV will not trigger faults (which I am not doing on my diagnostic tool), may cause knocking and can also cause hunting RPM on idle which was the 'ah ha! maybe that's it!' moment as I've got this recently too. So anyway, plan is: new valve in, re-remap to standard map, pump learn and pilot correction, then remap again.. Fingers crossed it'll purr again like new.. Part is in the mail Solved the bowel problem, working on the consonants... |
6th Jan 2017 12:11pm |
VCV solved it.
Very happy chappy, I no longer am envious of the rubbish truck's engine sound. Solved the bowel problem, working on the consonants... |
20th Jan 2017 9:05pm |
Happy to hear!
22nd Jan 2017 2:02pm |
