Home > Puma (Tdci) > Fixing diesel knocking at home.. Possible? |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 |
Hi!
I have the same issues as you and will get four new injectors tomorrow. I also intend to have the seals replaced. Copper gaskets have been already done. Did you already check the injectors return flow of diesel? If they are out of tolerance, that's a good indication for them being the culprits. Will keep updated on how my operation goes. e_d |
4th Jan 2017 11:32am |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
Four new injectors - wow $?
What is the difference between the seals and copper gaskets? Maybe I need to read up more on this! Solved the bowel problem, working on the consonants... |
4th Jan 2017 12:34pm |
Yeah, might be slightly overkill. But 1+3 and are slightly out of tolerance alrerady, my car has 70k miles on it. They'll be done for sooner or later, and all repairs surrounding the injection system are rather pricey, as I found.
I had the copper gaskets fixed already. The gaskets are worth pennies, but the procedure was was £ 850 (Problem is, apparently, with the Puma you cannot reuse the fuel lines and have to make it all new again). And, to my dismay, it did not cure the problem. So everything has to come off once more, new fuel lines, etc. And since I do not want to have to take off everything a third time, I figured that I might as well replace the injectors, seals (as I understand it the injectors have two more rubber seals that can also leak), and new copper gaskets again at the same time. It's scheduled to be done tomorrow, so if I am wrong, please chip in and let me know before I'll bleed a substantial sum of cash, totally unwarranted... |
4th Jan 2017 12:54pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
I've changed thousands of injectors and have never had to replace the fuel lines before......maybe this is something peculiar to the Puma engine.
I'd be interested to know the reason if anyone can enlighten me I started with nothing and still have most of it left! |
4th Jan 2017 1:01pm |
My mechanic says it's mandated by LR that on a Puma engine, removed fuel lines have to be discarded. Apparently the lines are even self-tapping and cannot be put back on even if one wanted.
So they say |
4th Jan 2017 1:06pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
There is a recomendation about replacing metal fuel lines, but I have done many using the originals and never had a problem.
I would recommend replacing the small leak off O rings (usually green in colour) or at least have some spare ones to hand, as they are very easy to damage when refitting the leak off pipes. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Jan 2017 2:27pm |
And this is exactly what I presume happened last time, as my diesel knock got better, albeit persisted, with new copper gaskets.
Said copper gaskets were replaced, but the green O-rings were not. Tomorrow, new green O-rings and - while were at it - injectors - and then: hopefully all will be well. I've been driving with a ever so slightly knocking 110 now for a year, muffling it by using premium diesel. But that's no long term strategy. |
4th Jan 2017 2:36pm |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Hi, Is this based on Puma injectors, or many injectors replacements in general? I guess if the lines are removed, then your effectively stripping back to the pump, or does it stop at the fuel rail I wonder? If it stops at the fuel rail, is it not being replaced due to the fact its a forged component and thus very very hard, and not likely to be deformed - I wonder????? I guess the risk is that the new made connection (using old lines) has a weakness and the chance you could have high pressure fuel spraying inside the engine bay @ circa 1200bar. I would guess its a very small chance, but maybe something LR see as a genuine risk, hence the recommendation. Cheers Andy |
4th Jan 2017 7:10pm |
As I recall, it stripped back to the fuel rail. I also faintly remember the rule existing due to fear of contamination with dirt or residue. Apparently, common rail systems are rather delicate.
4th Jan 2017 7:19pm |
So:
Fixing diesel knocking at home.. Possible? Sounds like no? Solved the bowel problem, working on the consonants... |
4th Jan 2017 8:08pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3612 |
Hi Agent Mulder , why are 2 of your injectors in the video jumping about like they are not clamped down, i have a 2.4 and the injectors are clamped solid in the head? DEFENDER 90 TDCI XS,
4th Jan 2017 8:11pm |
Yeah, they weren't clamped, bolt worked itself loose, refastened the current one but a new pair in the mail as they are 'torque to yield' bolts.
Hell of a clatter that the video doesn't do justice. Running as per normal again, but the process got me thinking about what I can do about knocking with the stuff I can access as easily.. Solved the bowel problem, working on the consonants... |
4th Jan 2017 8:57pm |
Puma Engines/ Transit engines, obviously cleanliness plays a major part in these components, but as long as your carefull you should be fine. I've never had any issues with leaks or pressure drops, only from leak off O rings which become hardened over time. I worked on Scania trucks for a while and it was always well documented that the fuel lines were replaced when removed, but generally the customer would not be willing to foot the bill for new lines, (serious money!) so the old ones were reused without issue with the owners consent, and these were running a much higer pressure than a 4 pot diesel. There was a story of one technician at another depot who had a fuel rail presure valve blow out, which left the fuel rail, through the rads, and grille, and through the workshop wall and out the other side! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Jan 2017 9:53pm |
The culprit has been found.
Anybody sees something unusual? |
5th Jan 2017 12:08pm |
