Home > In Car Electronics > Drl question. |
I don't. If you read my first post I want the Drls on with sidelights which I have on every time I drive so the rear lights are on too. When the headlights go on I want the Drls to switch off for the reasons you put forward. Ray
18th Nov 2016 12:10am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
^^ Sorry, I was getting a little sidetracked by some of the earlier replies which seemed to be suggesting that this mught be an approach, I realise that it actually isn't what you had specifically asked. My comment was not intended as a criticism!
18th Nov 2016 9:19am |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1205 |
I have a set of drl on my 110. The are wired into the headlight dipped beam feed. I took the view they must go out on dipped beam only. A useful unintended benefit is they come back on when on main beam, it makes a real difference to the illumination. The 110 has been thorough at least 4 mot's with no comment. I did consider adding a relay to have the side lights & DRL come on with the engine running (like a volvo) but in the end did not bother. |
18th Nov 2016 9:36am |
No worries Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th Nov 2016 10:37am |
Excellent thanks good to know it'll get through an mot Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th Nov 2016 10:39am |
It certainly shouldn't be a problem on main beam since you can have non-obligatory (and dazzley) lights on with main, although there may be certain restrictions on positioning and you may need a warning light under some circumstances.
You should fail an MOT if you have DRLs which either come on or stay on with dip beam, since these are obligatory lights and there are restrictions on their brightness and positioning. The same is true for sidelights although I don't know if the MOT test would actually pick it up. I suspect that the offence would be using this combination, rather than having it. If you were driving during the period of twighlight (ie the period when sidelights are required but headlights are not) on sidelight and DRLs, you are breaking the law. Similarly if you are driving on a road with a 30mph limit and regular streetlights during the hours of darkness on sidelights and DRLs you are again breaking the law. In both these situations it is wholly legal to drive with sidelights only and without headlights. It is not illegal however to drive with sidelights and DRLs in daylight hours, as far as I know, and there would be no logic for it to be so. |
18th Nov 2016 12:19pm |
thankyou, daylight hours are when I'd like drl and side lights on and dusk/night are when I'd have headlights on so that's perfect. Ray
18th Nov 2016 12:31pm |
18th Nov 2016 12:34pm |
18th Nov 2016 12:43pm |
Sorry, Internet connection playing up Ray
18th Nov 2016 12:44pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2289 |
Hello mk1collector
You ask a good question, and I too have come at this from a 'habit' of driving always with my side lights on. I have a set of Lyra DRL which I'm about to fit. They are designed to work, as I understand it, in a way now required for UK DRLs (dangerous comment I know, thinking you know something) They are wired into a Permanent Live (Battery via a 2A fuse) + the Side Lights and Earth. The Lamps automatically come on with the ignition (when Engine is Started) and are in Daytime Running Lamp Mode (long reach beam) when the side lights are switched on they reduce in brightness + create a Night Styling Function (shorter reach beam) My issue (not related to your question) is that I want to place them where technically they would be illegal behind my KBX grill as shown...they would be too close together as the placement diagram shows. May add in a switch to cut them out for MOT's or may just place them under the headlights in a way as yet to be determined Click image to enlarge What I want to do What I should do What I have Good Luck with yours SKIP https://www.defender2.net/forum/topic83242.html |
18th Nov 2016 2:25pm |
flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290 |
Not sure about the wiring, how does this work?
"They are wired into a Permanent Live (Battery via a 2A fuse) + the Side Lights and Earth. " As for the MOT, you could just pull the fuse |
18th Nov 2016 2:47pm |
Hi flydive
Wiring Instructions read: White Wire to battery + terminal with a 2A Fuse (I would connect this via a blue sea terminal fuse box / already fitted on mine) Yellow Wire to Vehicle Side Lights Black Wire to Earth 'The built in automatic switching unit allows the lights to be illuminated as soon as the engine is switched on. Once the side lights are switched on the lamps will reduce in brightness to create a night styling function' May turn out somewhat different when installed but appears simple from Instructions... SKIP https://www.defender2.net/forum/topic83242.html |
18th Nov 2016 3:18pm |
Thanks for the info skip I didn't realise about the regs for placement but I think I'll be ok as I'm going for a reasonably standard drl bumper. Ray
18th Nov 2016 3:27pm |
