Home > Maintenance & Modifications > Puma - making ventilator fan quieter
glpinxit
Recognising that I'm a bit fussy, I'd like the ventilation fan in my MY'15 XS to be quieter. On setting 1 it is nearly as loud as it is at setting 2. Once I'm out of town other Defender sounds mean it isn't noticeable but I'd quite like to be able to stop switching the fan off in traffic. Is it just me or has anyone here found an easy way to quieten it down? Cheers, Guy.
Post #492848 16th Jan 2016 8:48am
Cupboard
It's certainly not just you. It is remarkably loud, a bit like the rest of the Defender Laughing
Post #492869 16th Jan 2016 10:27am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I totally agree. Often the first speed is too loud, but switching it off results in total loss of heating.
An additional resistor built into the wiring ought to do it. Rolling Eyes
Anyone here know enough about these things to offer a suggestion? 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #492878 16th Jan 2016 11:11am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
A pair of "Ear Defenders" works well, excuse the pun! Smile 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #492884 16th Jan 2016 11:30am
Wild Card 90
Thanks for the suggestion. Such wisdom could only come from the owner of a Series and an old Norton Laughing Laughing Laughing 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #492895 16th Jan 2016 12:05pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
take it of recirc? 1953 80"
1987 mini city e
2011 90"
Post #492903 16th Jan 2016 12:28pm
glpinxit
Definitely a million times worse on recirc but I almost never use that. Without opening the dash (which will happen, but not yet) I can't tell if it is due to corrugated ducts or something else. Cheers, Guy.
Post #495676 23rd Jan 2016 11:07pm
Wild Card 90
Travelling home from town in traffic yesterday, and observing the reactions to different settings, I come to the conclusion that it is not just the fanīs noise that irritates. It needs a lower speed setting.
Driving slowly in traffic on a cold day the lowest speed is still too much air, but with the fan switched off, there is no flow of air due to the slow vehicle speed.
It is a relatively insignificant issue, but I expect there could well be a relatively simple way to drop the speed of the fan over a resistor or potentiometer, to find the sweet spot.
glpinxit, it is a good sign, when such minor issues are so high on the priority list....on a Defender. Razz Rolling Eyes 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #495729 24th Jan 2016 9:39am
Alexke
Belgium
You could ad a resistor or if you want to be REALLY picky about speed :
http://www.dx.com/p/jtron-12v-24v-30v-120w...qa_qIXhDuo
or
http://www.ebay.com/itm/2000W-40A-12V-24V-...SwjVVVvrzr
You should use a PWM controller.
http://www.instructables.com/id/Retrofitti...eed-contr/
and if you want to be incredibly fancy you could engineer some sort of cabin temperature based speed controller... (but you will have to have an override) Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #496452 26th Jan 2016 1:37am
Wild Card 90
Alexke, thanks, that should do the job. An extra knob beside the heater controls, so that each of the three speed settings can be fine tuned. Excellent. Youīre the man! 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #496457 26th Jan 2016 6:36am
Alexke
Belgium
and if you use a NO-NC switch you can have double the amount of speed positions. Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #496542 26th Jan 2016 11:35am
JOW240725
I totally agree the fan on lowest setting is noisy but also gives too high an airflow. I agree with Wild Card turn it off and everything steams up but on level one it's too high and constantly have to adjust temperature for it to be comfortable. Unfortunately the above adjustable suggestions are electrically beyond me! I'd be interested to hear how people get on who do try it though. Thumbs Up
Post #496575 26th Jan 2016 12:59pm
Happyoldgit
Models prior to the Puma had fairly dire blower and heating, now the Puma's have too much puff Laughing Steve.
http://forums.lr4x4.com
Post #496617 26th Jan 2016 2:40pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Well coming from my old TD5 where the first fan speed was like an asthmatic snail on a bad day compared to speed 2 where your ears would bleed if it was on too long.
Also on either setting you had a good half hour before it gave out any heat so I consider the Puma the height of luxury.
Stick on a good CD and turn up the volume till the other noises (fan, rattles, clunks, etc.) are inaudible - job done!!
Post #496622 26th Jan 2016 3:09pm
Alexke
Belgium
That is the first mod I actualy did Smile : big ass sub , gone were the sounds. Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #496691 26th Jan 2016 5:54pm
