Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
I do keep looking at drl bumpers but can't decide if I want round or rectangle lights I suppose as its a defender it should be more about use and purpose but I like asthetics too and my symmetry ocd is throwing in a curve ball with the other lights on the front being round Ray
26th Jul 2015 12:02pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
IMO looks better without........ be different don't bother
26th Jul 2015 12:05pm |
I think it's time to come clean I'm addicted to changing things Ray
26th Jul 2015 12:18pm |
I'll look out for it. Ray
27th Jul 2015 8:14pm |
Got my nas step back from the powder coaters (again) today and although it's not perfect, it's a lot better than last time I picked it up so I'll leave it for now. I put it on and waxed the whole of the inside but forgot to put something underneath on the floor so half an hour later I also had a waxed drive
Click image to enlarge I managed to tidy up the crossmember this week in prep for the step coming back so all I need to do now is refit the wheel carrier oh and put a new rear door on Also managed to find one of these as I shouldn't need to tow anything with this one. Click image to enlarge Click image to enlarge Thanks for looking Ray My build thread http://www.defender2.net/forum/topic17615.html |
30th Jul 2015 5:41pm |
All back together now and I think it looks lots tidier also the rattle has gone from the old step which is a bonus. I did have to take more off the wheel carrier to get it to fit though.
Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
2nd Aug 2015 6:50pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1751 |
Looking sorted Ray. Where did you get the NAS bung from as I have that setup on my JPN 50th?
2nd Aug 2015 8:40pm |
Hi, I ordered from britcar but after a week they decided they couldn't get one but gave me the number for mode Landrover which were showing one left in stock. Ray
2nd Aug 2015 10:45pm |
My fingers now have lots of cuts again but the first layer of sound deadening is on the roof!
All stripped out Click image to enlarge First layer on Click image to enlarge Because the roof is big, flat and wobbly I'm putting two layers of deadening on and then the closed cell foam which is Ali faced so it should be quieter, warmer in winter (with no condensation) and cooler in summer. The other layers will go on next week when I have some more free time Ray My build thread http://www.defender2.net/forum/topic17615.html |
6th Aug 2015 3:23pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Makes a big difference I found
6th Aug 2015 8:00pm |
Yeah, when I did the bottom half it made a big difference if the top half makes the same improvement it should even be pleasant to drive on the motorway Ray
6th Aug 2015 8:38pm |
Finally got around to putting the roof back together and with two layers of sound deadening and two layers of closed cell foam it should be a lot quieter
8 square mtrs of this Click image to enlarge Gives total coverage twice over the top of the sound deadening. From this Click image to enlarge To this Click image to enlarge Also added in another courtesy light for the middle row while everything was out Click image to enlarge And all beck together looking standard apart from the extra light Click image to enlarge I might look out for a black headlining next Thanks for looking Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
16th Aug 2015 3:57pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 804 |
Good work Ray. Let us know how much difference it has made 2002 110 td5
16th Aug 2015 4:54pm |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 |
That is a really good job! I am having the dealership install the third courtesy light as they are sorting out a roof problem under warranty also installing some roof insulation but nothing like the job you are doing! That is top notch! Well done!
16th Aug 2015 5:12pm |
