Home > Maintenance & Modifications > Multiple and individual lights |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Yes you can mate. its all about switches and relays.
How many lights are you talking about. |
11th Apr 2015 6:59pm |
chrispy Member Since: 14 Mar 2015 Location: Gwent Posts: 347 |
LED light bar on the roof, front spots on the bumper, side lights either side and work lights at the back.
11th Apr 2015 7:06pm |
I'm no expert in vehicle electrics but this would be my thinking.
Install and additional fuse box in the battery compartment. Install a bank of switches into your cubby box and switch them all separately. You could then install a relay to switch all front lights on together, I can't see the point of having the rear ones on with the front. |
11th Apr 2015 7:14pm |
Ready for the zombie apocalypse lol. Thanks very much my friend
11th Apr 2015 7:15pm |
Your welcome
11th Apr 2015 7:19pm |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 297 |
If you want to avoid extra relays etc etc then in line diodes are your friend. They usually come as a 10a black cased unit, a bit like a stubby pen tube with a 6.3mm male blade crimp on one end and a female on tother.
Use them to isolate the LED feeds individually, then just feed them all from a common relay elsewhere, just be careful of the 10a limit (or double them up etc). Do bear in mind they are about 3 inches long so not good for very tight spaces, but fine for trunking. On my freelander I have my headlight full beam linking into two seperate banks of LED Spots, but these can be also turned on manually. As a third twist, I can also link and unlink the LEDs into the main beam at will. Hope this helps. Duncan @ UTV Products (Led Lighting Suppliers) North Cumbria Search and Rescue - Team Leader |
11th Apr 2015 7:37pm |
Very helpful many many thanks
11th Apr 2015 7:39pm |
I'm at the planning stage Duncan and just found your website. When the time comes i'll be in touch and you can help me out with everything I need if you don't mind. |
11th Apr 2015 10:03pm |
Hi mate. Absolutely not a problem. I would have linked to it but don't want to poke Martin with a pointy stick just yet haha. Drop me a PM any time. North Cumbria Search and Rescue - Team Leader
11th Apr 2015 10:10pm |
Thank you my friend. A little way off yet i'm just getting everything down on paper as to how we want it to be. I love your LED bar's especially those colour changing ones, i've never seen those before.
11th Apr 2015 10:14pm |
