Home > Td5 > So I have the engine out and the head off |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
Would you take lots of pictures please ?
21st Mar 2015 11:45am |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
Also I forgot to ask, if I want to de gunk the top of the cylinders can I remove the timing chain completely to crank over the bottom end, clean and then re time by finding tdc of the no 1 piston and re lining up the chain with the one marked link at the bottom and the two marked links at the top?
21st Mar 2015 11:47am |
I can take a few of the head stripped down. and the bell housing. Will get on it before the rugby starts and upload later
21st Mar 2015 11:48am |
Block
Click image to enlarge Click image to enlarge Click image to enlarge Timing chain did not have the two black links described but two with script engraved that lined up. Click image to enlarge Head stripped Click image to enlarge Click image to enlarge Click image to enlarge What the rocker cover looked like Click image to enlarge Cam shaft Click image to enlarge Injector clamps etc all kept in order Click image to enlarge Injectors bagged and labelled Click image to enlarge Leaking FPR Click image to enlarge Bell Housing gunk Click image to enlarge Fly wheel Click image to enlarge Sad Landy Click image to enlarge |
21st Mar 2015 2:00pm |
Inlet manifold nice and clean and no oil in the intercooler. Might put an alisport one on
Thinking of replacing the cooling hoses as they are worn in places. |
21st Mar 2015 2:02pm |
Click image to enlarge Other side of the water pump |
21st Mar 2015 2:03pm |
I would like to get everything as clean as possible before reassembling, ideas?
21st Mar 2015 2:08pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2877 |
Dishwasher
21st Mar 2015 4:15pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
That's all well and good if you can smuggle it into the kitchen without a certain someone noticing.
Then trying to explain why you have a sudden urge to use the dishwasher all night! How do I know? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
21st Mar 2015 4:27pm |
I am totally cool with using the dishwasher but Im worried about the internal fuel feed, will it contaminate anything?
21st Mar 2015 5:15pm |
just seen this https://www.youtube.com/watch?v=6qs7qsCPabI
21st Mar 2015 5:30pm |
Thanks for the pictures - great to see !
If you are ticking off problem areas whilst it's out - you could check the oil pump bolt, uprate the exhaust manifold studs, new o rings in the fuel cooler, and check the oil cooler for corrosion ? |
22nd Mar 2015 9:44am |
Love that YouTube ad !!
Though that spanner must have hurt "ouch!" |
22nd Mar 2015 9:49am |
Raywin Member Since: 27 Feb 2015 Location: North Yorkshire Posts: 48 |
Only had my td5 a year and a half but have done quite a bit of reading on the subject, so when I did my clutch-flywheel I put clear silicone onto the face of the bell housing when I replaced it so if you get a diesel leak then it won't run into the bell housing and contaminate the clutch.
22nd Mar 2015 10:04am |
