Home > Maintenance & Modifications > What are the best diff guards for a MY13 110?
Page 3 of 3 <123
Jim_Bean
ozzie1989 wrote:
Jim_Bean, what did you pay after?
145 delivered for the front and rear guards.
Post #404185 3rd Mar 2015 7:42pm
x-isle
You won't be disappointed. You'll find you need to lever the front one to meet with the bracket and the rear one might need a ratchet strap to compress it to meet with the bracket. Wire brush the studs before removing the nuts as they'll get very tight and stiff otherwise.
Oh and get a tap ready for the 2 holes you need on the rear diff casing. They are threaded but they'll be full of road crap.
Just a few things I found out last weekend. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #404238 3rd Mar 2015 9:27pm
Jim_Bean
Rear diif guard fitted Thumbs Up
The front one just doesn't want to fit around the front diff. It just seems too small to go around the bulge in the front of the diff.
Craig - was it a really tight fit? Did you have to remove the steering bars to get it to fit?
Post #405324 7th Mar 2015 4:22pm
x-isle
No, but I've heard this before that others have had issues with the front and not the back. Mine was the other way around.
Just be brute and it will all bend into shape. It's what I had to do with the rear one and a ratchet strap as it was miles out.
 Craig Rogers
2007 Puma 110 XS
Post #405378 7th Mar 2015 8:13pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
can any off you who have fitted Wild Bear diff guards recently help me out. Have a look at my post please I have mixed up the top brackets. can anyone confirm which goes with which before I go crawling around under my def
http://www.defender2.net/forum/topic49626....a7946e0dcb
Post #568444 3rd Oct 2016 5:53pm
roliver
United Kingdom 2009 Defender 90 Puma 2.4 ST Tamar Blue
Hi all,
I phoned QT/Wildcat earlier and apparently they're not manufacturing the Wildbear diff guards for Bearmach any more Sad.
Does anyone have any other recommendations? I'm looking for front/rear guards for a 2009 Defender 90.
Cheers,
Richard
Post #625421 19th May 2017 4:42pm
diduan
Bulgaria
Unfortunately ARB do not make their diff cover for puma axles. Here is something similar https://www.devon4x4.com/d44-heavy-duty-di...black.html Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #625476 19th May 2017 8:30pm
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
You could always try APT Fabrications here in Oz, Ben's gear is top notch, postage might bite a bit though.
http://aptoffroad.com.au/browse-catalogue/...pathway-13
Ooops just noticed that yours was a 90, the above link is for the P38 rear on the 110.
This is the one for the 90, http://aptoffroad.com.au/browse-catalogue/...pathway-13
Post #625505 19th May 2017 11:15pm
roliver
Thanks for the advice. I've got a feeling that shipping from Australia will be a tad on the expensive side though!
Post #625571 20th May 2017 12:30pm
If the QT / Wildbear versions aren't around. I have the firmer I'd definitely be looking at the D44 HD diff pans. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #625572 20th May 2017 12:42pm
roliver
Just an update on this in case anyone's interested.
Just phoned LRS offroad this morning.
They stock the Corsetti diff guards at ~ 117 but they've also started making their own clone version at ~ 85. Apparently the only difference is the label on it.
Cheers,
Richard
Post #625994 22nd May 2017 11:27am
Page 3 of 3 <123
