Home > Maintenance & Modifications > What are the best diff guards for a MY13 110? |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
My old 90 survived a long time with just a standard 'rover' bolt-on guard on the front axle...
For the 110 I was just going to buy the two wraparound guards from Paddocks as they seem good value. Not got around to it yet mind, so I'd be interested in what you decide! Only thing with wraparound guards is that they do reduce the clearance slightly under the diff, although if you were to 'slide' over a rock on the guard that would be preferable to the rock hitting the diff no doubt! Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
2nd Mar 2015 6:28pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 755 |
Went through the same dilemma a couple of months ago,
Ended up with a first four wraparound on the front- its OK but was an arse to fit. the top bracket that fits over the top pf the diff is a bit disappointingly wussy. Have got a wildbear rear one to fit at the weekend, really wish I had gone for the front one as well- such a nicely made piece of kit. Have seen pictures of one fitted as well- fits like a glove. Chris |
2nd Mar 2015 7:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
QT wrap around, not cheap though.
2nd Mar 2015 7:35pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
QT
2nd Mar 2015 7:42pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
QT are now rebranded.
I tried to order some direct on the QT website but I had to ring them due to an "issue with their online payment". So I phoned QT and they informed me that they have been rebranded as Wild Bear as they are now distributed via Bearmach. They are exactly the same apart from the logo. Only the LHD versions require welding. The RHD ones bolt straight on. The Paddock ones, are really bad quality, the galvanising it terrible and the welds were rusty when they turned up, so I sent them back and bought the Wild Bear. I fitted front and back on Saturday. They are easy to fit, but do need some nudging to join the guard to the bracket. Also, with the P38 diff casing, it uses the 2 spare threaded holes on the diff casing. They will be filled with crap, so you'll probably need to run a tap through them to clean them out. Click image to enlarge Click image to enlarge Click image to enlarge Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Mar 2015 7:53pm |
Useful info above, I did notice they were remarkably similar but didn't think much more of it.
2nd Mar 2015 8:30pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 603 |
Perfect, thanks guys - top information as always
Qt/Wildbear it is. Just need to find a good deal... |
2nd Mar 2015 8:34pm |
Let me know if you find one Now: 2010 2.4 TDCi 110 Utility Wagon
2nd Mar 2015 8:49pm |
Hi x-isle
Did you know which Wildbear guards you went for? I think I need a BA 7602 for the front and a BA 7610 for the rear. BUT the description for the BA 7610 is for 'Defender 110/130' and the BA 7607 is for 'Defender 2007 on' Somewhat confusing. |
2nd Mar 2015 9:18pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 706 |
I couldn't see from the photos but does the front diff guard offer protection to the output flange like the rear version does? |
2nd Mar 2015 9:21pm |
Double post - sorry.
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Corsetti 4x4
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge http://www.davidecorsetti.com/prodotti.php...d_cat3=126 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
2nd Mar 2015 9:43pm |
After speaking with QT, they suggested ordering from Mailorder4x4 I had never ordered from them before, however, as QT themselves suggested them, I thought I'd give them a go.
These are the ones you need; FRONT (Same as the QT model A1050A) http://www.mailorder4x4.com/performance-pa...-1998.html REAR (Same as the QT model A1080) http://www.mailorder4x4.com/performance-pa...0-130.html One thing that was wierd and I'm guessing is because it was dispatched direct from Bearmach (which incidentally is based in my home village in Wales) I had an email stating it was on backorder, then about an hour later it was dispatched and it came next day. Very happy with Mailorder4x4!
No it's slightly different as it bolts in place of the steering arm guard. I haven't got a photo, but did find this on the internet. As you can see, it's a fair way up inside, so not likely to catch it. Click image to enlarge[/quote] Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Mar 2015 10:07pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1168 |
Some nice stuff on the Corsetti website that I can't for the life of me figure out how to order!!
G My confidence has been writing cheques that my abilities can't cash for years. |
2nd Mar 2015 10:39pm |
