Home > Puma (Tdci) > Puma fuel bleeding pump |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
18th Sep 2008 8:03am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Yes it was a standard item, however the supplier found them in a box of odds and sods so could not tell me where they got them or what they are called. I have posted pictures on the D3 site as some of the guys over there have 'contacts' and there is more of them. http://www.disco3.co.uk/forum/post345511.html#345511 I will continue to see if I can track them down. Basically all you need is a male end that is about 9.6 to 9.9 Ø and about 20 to 30 long. |
18th Sep 2008 8:12am |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Now to obtain the difficult bits as there is currently no stock in town of clear plastic tube or the rubber pump I'll also have to source the plastic bit.[/quote]
Wow - you must be pretty remote then Those of us in bigger places don't apretiate how lucky we are to have so much variety in choise of materials and services. Puma 110 - gone Series III 1973 - going strong |
18th Sep 2008 9:14am |
So your nearest Land Rover service centre isn't 1100km away - 680km is dirt track and there are numerous water crossings?
110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
18th Sep 2008 10:01am |
If a male is so thin and as short as 20 - 30 he is probably Chinese or Indian Puma 110 - gone
18th Sep 2008 10:05am |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 |
Hi Andrew,
I think that the TD5 discovery fuel connection is the same. I will check out the dimensions. I keep the short pipe (which would have both male & female connections on it), which was used on the recall on discovery tank pipes where they rubbed through. These are quite cheap & if the same dimensions would be very easy to use. I'll post back ASAP regards Steve |
18th Sep 2008 11:10am |
No the TD5 connections are 8mm, so no good.
Regards Steve |
18th Sep 2008 11:16am |
Are there any other connections the same as that on the vehicle?
The price from Landrover for the fuel line £26+vat for the bit between the filter & the fuel cooler, this seems to have both male & female connections on it. The fuel line from tank to filter is only about £15+vat, but am unsure of the connections at the tank end. HTH Regards Steve |
18th Sep 2008 11:36am |
how did you manage to go through so many filters already Puma 110 - gone
25th Sep 2008 7:51pm |
Managed to score a boat tank from my brother whos said it was leaking - only found a dodgy top gasket (but the less said the better)
Anyway, machined a fitting as per previose post and now have a fuel bleeder just in case. to Landrover SA Click image to enlarge Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
4th Nov 2008 6:59pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
that first photo of the dodgy looking fuel....
its not bio diesel is it? how did it get so contaminated? |
10th Nov 2008 3:01pm |
That diesel came from my company Toyota diesel and was used to clean some dirty engine bits.
Cheapest engine cleaner in the world. (company diesel card) I tested the pump in the jar before I cleaned the bits in the jar. Still need to test the pump on the Puma but the measurement is exact to the drawing so I am not in a rush to test the contraption as yet. Puma 110 - gone Series III 1973 - going strong |
10th Nov 2008 5:53pm |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
is someone so gentle to convert measure in metric unit??
Matteo Defender 110 Td4 SE MY 09 |
6th Sep 2010 1:19pm |
I bought it from a diesel injection workshop for 22,00€ (build from DEPLHI).....
Matteo, 1 pollice (1") = 25.4mm ma il disegno è già in mm............................ The quotes are still in metric Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Sep 2010 2:02pm |
