Home > Technical > TD5 110 dead after transfer box swap (electrical) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5428 |
All I can think is immobiliser come back to life due to fiddly with battery, or possibly damaged the loom as it goes over the top of the box?
Andy |
17th Jan 2015 3:08pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
I thought the loom over the box might be worth a shot as well. How hard is it to remove an aftermarket immobiliser? Its scotch block city behind the dash
17th Jan 2015 3:14pm |
main earth lead from battery to transfer box ?
normally bolts to transfer box , so you would have taken it off , have you refitted it ? Last edited by munch90 on 17th Jan 2015 4:45pm. Edited 1 time in total |
17th Jan 2015 3:17pm |
Check all your relays under drivers seat.
Isn't there an earth that goes onto the trans box? What does starter do when you try to start? |
17th Jan 2015 3:18pm |
nothing from the starter, I have pulled all the relays which look good, the start relay clicks.
17th Jan 2015 3:30pm |
Have you checked all fuses, including those underseat?
17th Jan 2015 4:05pm |
yep
17th Jan 2015 4:19pm |
+1 Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
17th Jan 2015 4:31pm |
17th Jan 2015 4:46pm |
yes
17th Jan 2015 4:47pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
And the little earth lead from the R/H side of the transfer box?
17th Jan 2015 5:01pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6044 |
^^^ Just what I was going to say.... usually 2 wires crimped into one eye. 10mm head bolt. not easy to see from underneath.
17th Jan 2015 6:32pm |
will have a look in the morning
18th Jan 2015 12:55am |
