Home > Technical > TD5 110 dead after transfer box swap (electrical)
Welkman
Hello,
Have an issue with my TD5. It is refusing to crank along with having no gauges on the dash. Lights, stereo etc work, relays and fuses all good, a bit of oil on the red ecu connector. It has a arianne alarm system fitted but I did not think it worked. I am wondering if it has immobilized itself due to the battery disconnect? I have no fob for the alarm. It is a farm spec model and was running fine before the transfer box swap. All the earths are clean as well.
Anyone have any experience of this? Fuel pump comes on and the starter relay clicks but nothing on the dash.
Thanks
James
Post #389365 17th Jan 2015 2:17pm
landy andy
All I can think is immobiliser come back to life due to fiddly with battery, or possibly damaged the loom as it goes over the top of the box?
Andy
Post #389386 17th Jan 2015 3:08pm
Welkman
I thought the loom over the box might be worth a shot as well. How hard is it to remove an aftermarket immobiliser? Its scotch block city behind the dash Sad
Post #389390 17th Jan 2015 3:14pm
munch90
main earth lead from battery to transfer box ?
normally bolts to transfer box , so you would have taken it off , have you refitted it ?
Post #389392 17th Jan 2015 3:17pm
landy andy
Check all your relays under drivers seat.
Isn't there an earth that goes onto the trans box?
What does starter do when you try to start?
Post #389394 17th Jan 2015 3:18pm
Welkman
nothing from the starter, I have pulled all the relays which look good, the start relay clicks.
Post #389401 17th Jan 2015 3:30pm
landy andy
Have you checked all fuses, including those underseat?
Post #389412 17th Jan 2015 4:05pm
Welkman
yep
Post #389417 17th Jan 2015 4:19pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
+1 Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #389418 17th Jan 2015 4:31pm
munch90
Post #389420 17th Jan 2015 4:46pm
Welkman
yes
Post #389422 17th Jan 2015 4:47pm
Fatboy Slim
Wales
And the little earth lead from the R/H side of the transfer box?
Post #389425 17th Jan 2015 5:01pm
^^^ Just what I was going to say.... usually 2 wires crimped into one eye. 10mm head bolt. not easy to see from underneath.
Post #389465 17th Jan 2015 6:32pm
Welkman
will have a look in the morning Smile
Post #389621 18th Jan 2015 12:55am
