Home > Technical > TDCi - fuel feed system |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 |
No. The TD5 has the pump in the tank giving positive pressure in the fuel lines through the filter to the engine. The TDCi has a pump unit on the engine which creates a negative pressure in the fuel line drawing the fuel through the filter to the engine. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG |
10th Sep 2008 6:14am |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Interesting. Hence the issue of water being ingested via the fuel tank breather valve. A postive pressurised tank would not have the same problem. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
10th Sep 2008 7:54am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7722 |
so if i needed to get a fuel supply for a webasto i would need to go straight to the tank then i guess? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
10th Sep 2008 8:37am |
The td5 tank doesn't get positive pressure, it still holds a partial vacuum as it drains, it just doesnt seem to get as big as the TDCi. When I open the fuel cap on my TD5 you can hear the air get sucked in when the seal breaks. I do have long range tanks though (150l). Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
11th Sep 2008 6:34am |
I guess you take it from the fuel return line, that would be under some pressure. Wether it would have the volume and pressure required for what you want I don't know. Taking a separate feed from the tank may indeed be a better/safer option. Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
11th Sep 2008 6:39am |
Webastos come with their own feed pump so i guess from the tank may be the way to go.
Thank you Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Sep 2008 7:11am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
James
Would not bother with the webasto , Puma's have a heating system Just can not see the hassle of fitting / swapping over, worth it California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
11th Sep 2008 8:21am |
thats what i was thinking, ones at work seem to warm up a lot quicker than the td5 so i am unlikely to bother but was just wondering
maybe the tdci warms up quicker due to the lack of oil in the top part of the engine.......... Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Sep 2008 8:27am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5028 |
The puma's warm up just a quickly as most modern cars (and like any other tdci ford) so i would say you wont need one.
Whilst im waiting i put the heated seats on (although we have only had 1 cold morning since April to test it) Mike |
11th Sep 2008 4:30pm |
