Home > Maintenance & Modifications > Steering box replacement |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5429 |
Talk to Adwest direct for best advice and prices. What's wrong with yours?
Andy |
14th Nov 2014 9:24am |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 363 |
Cheers Andy,
I'll drop them a email today. From what he was saying and what I've noticed. There is a lot of play in it at the centre position. I've not managed to have a loo at it & see if there are any leaks eto yet. I've got my sick little one not letting me put him down!!! To be honest I don't know much about them & what problems occur etc and what checks can be done. Cheers for the reply. 2006 Defender Double Cab- Zambezi Silver |
14th Nov 2014 9:33am |
You can adjust the box. When I wanted to get a new box on my 04 Td5, I spoke to Adwest who told me I didn't need one and told me I needed a new shaft instead. So can't fault them.
Andy |
14th Nov 2014 9:42am |
Thanks Andy,
I'll have a look and play with it later & see what I find. 2006 Defender Double Cab- Zambezi Silver |
14th Nov 2014 9:46am |
Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 169 |
As said, it's adjustable. First job should be to check if you can minimize play by just tightening it. New ones are silly expensive. I just had mine rebuilt and its absolutely fine now.
14th Nov 2014 10:28am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16943 |
If you do need a replacement, as suggested above talk to Adwest. Adwest also supply reconditioned boxes but they are at least recoditioned to OEM standards, unlike, it would seem, Landrover parts. I would have no qualms about a box reconditioned by Adwest.
I needed a replacement box for my Disco2 some years ago (essentially the same as the Defender box) and had an appalling experience with Genuine Parts boxes. First problem is that they are all "reconditioned" not new, second problem is that they seem to be reconditioned by a blind incompetent with the wrong tools. The original (Adwest) box lasted something like 140k miles then developed a minor leak. The first Genuine Parts box didn't even last the 40 mile journey home before developing a worse leak than the original, due to one of the seals being incorrectly fitted. The second GP box lasted until it was a week or so out of warranty and then developed a catastropic leak due to poor assembly quality. At that point I bought a second-hand box from a similar but lower mileage vehicle via Ebay, which was one tenth the cost of the GP boxes and has lasted over 60k miles without problems. |
14th Nov 2014 11:28am |
Thanks Timo,
I'll have a look at that. Thanks Blackwolf, I've read quite a few stories about poor quality boxes and then not lasting. I'll contact adwest & see what prices they offer on recon/new. Just had a quick look at it, I can rock the input by hand quotes easily just before the box with no output in the arm at the bottom. I don't know if that's right or wrong though. There are no leaks I can see. It does look like it would be a real PIA to remove though!! 2006 Defender Double Cab- Zambezi Silver |
14th Nov 2014 12:47pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
If you do go for a new one go for ether a 3 or 4 bolt one.
Try and stay away from the 6 bolt one, they are not as strong as the 4 bolt ones. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
14th Nov 2014 2:18pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2642 |
IIRC the 3 bolt box will have imperial fittings, so may need adaptors to get it to fit your metric system. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
14th Nov 2014 2:43pm |
Cheers Guys,
Had a look and mine is the 4 bolt version so I'll make sure I di like for like. Emailed ADWest and I'll see what they say. 2006 Defender Double Cab- Zambezi Silver |
15th Nov 2014 1:32pm |
