Home > 130 > It's started, Longshanks will no longer be a Pick up |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
A great build
Could you have used front doors as your second row doors ? With the extra length it looks like the angled doors could be bigger ? |
31st Aug 2014 12:20am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16885 |
Some of the stretched vehicles built at Solihull have used hybrid rear doors. I guess the difficulty is that you'd need to compine the bottom of a front door with the top of the back door, then fit a custom glass and lift mechanism to allow the full-size window.
Certainly a nice result but a lot of work. |
2nd Sep 2014 1:13pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Got 2 of the aux batteries installed into rock ard battery boxes
Click image to enlarge |
4th Sep 2014 11:06am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 576 |
More info please.
My idea is to place 2 105Ah under drivers reat (LHD) in my 130 TD5, or, because they are quite heavy, one under driver and second under the pasenger seat. Probably with some modifications of the seat box. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
5th Sep 2014 2:41pm |
Extended the 2nd row under-seat area and made the sub support.
Click image to enlarge Fitted the puddle lights that work with the interior lights ie they fade out. Click image to enlarge Oh and got the amber side markers connected up. Click image to enlarge |
10th Sep 2014 10:46pm |
Made the FoxWing to Hannibal Roof Rack adapters today
18th Sep 2014 3:16pm |
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 |
Great work as always
Where are the puddle lights mounted to ? Wing mirrors ? Nice modification |
18th Sep 2014 3:48pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
Any more pics of those hannibal to foxwing mounts? Picking mine up tomorrow, and fitting info is a bit thin.
Thanks Andy |
18th Sep 2014 3:50pm |
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 551 |
Looks great. The same with the mounts, if you can knock a few more up I'd be interested dependent on price.
I was intending to leave the side rails off but struggling to find a way to mount. The rack I have has the table towards the back which won't allow the standard brackets from boab to be mounted. |
18th Sep 2014 4:56pm |
Same here didn't really want the rail, but have fitted it for this weekends collection. Andrews one also looks nice and low, and awning does not stick up above rail.
Andy |
18th Sep 2014 5:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
From me.
18th Sep 2014 5:20pm |
Sorry for lack of info, we are so busy at work and having new machinery installed into the workshop. Work on the 130 has taken a back seat.
I hope to re start the build next week and will post more pics. With reference to the Foxwing to Hannibal adapters if there is enough interest I will start another thread. |
16th Oct 2014 5:06pm |
Managed to get a few days on the 130, mainly running cables for various items.
Got the mounting sorted out for the Eberspacher, its going under the second row seat box with the air ducts one coming out each side of the box. Sub is also mounted under the second row seat box with a S/S mesh flush fitted to the top of the box. Reverse camera fitted Rear side work lights fitted Driving and spot lights fitted to the front of the rack 1/2 way through fitting the double DIN Happy Days |
24th Dec 2014 1:56pm |
Yesterday I mounted the "under cubby box" for the amp. I know this area gets hot so I decided to fit an ally heat shield, the holes are for the cables.
Heat Shield Click image to enlarge Amp Box Click image to enlarge |
25th Dec 2014 12:51pm |
