Home > 130 > It's started, Longshanks will no longer be a Pick up |
stanstorey Member Since: 06 Mar 2012 Location: East Devon Posts: 118 |
I love threads like this, and good to see LR are still keeping to their build tolerances adopted in the late 40s.....
Look forward to watching it evolve! |
6th May 2014 9:06pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 695 |
Ooh .. mingin' .. 2008 Defender 110 XS SW - M57N2 / 6HP28X
7th May 2014 11:04pm |
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 |
its a transformer
7th May 2014 11:23pm |
Now that's going to smart for a few days Just something to remind you of the pain of having a Land Rover!
7th May 2014 11:25pm |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1038 |
It's only a flesh wound. Stop moaning and get on with it. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
7th May 2014 11:30pm |
Bit of T cut and it'll rub out
7th May 2014 11:39pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16883 |
Great thread, please keep the photos coming!
I am going to start saving now so that I can buy this one when the time comes for you to move it on! |
8th May 2014 10:16am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Looks great, absolutely love it Defender 90 XS TD5 (03 Reg)
8th May 2014 11:17am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
So hand is a bit better now so cracked on with the stuff that's going to the galv and powder coaters.
Finished the rock/tree sliders. Final fit before removal to be sent off. Click image to enlarge Oh decided to make and fit some ally fender extender things Click image to enlarge |
10th May 2014 9:31pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
That really is a beast of a machine, looks great!
Many will be interested in watching this thread, myself included. Keep up the good work. |
10th May 2014 9:45pm |
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 |
Did you fabricate the tree/rock sliders or are they off the shelf items ? Looks smart.
Must say i am getting some great ideas for my 130 project, been searching through forum yours is a beast of a truck. Respect |
11th May 2014 10:01am |
Rosso_NI I made the tree sliders
Slow progress today, yet again down to the varying differences in dimensions due to the Land Rover build. Its causing issues as I have no datum to work from.... Go and measure your Defender for instance the gaps between the A B and C pillars and compare the measurements, also measure the distance from the chassis to the outer body. So lots of time wasted measuring trying to work out where the differences in dimensions are, cant wait to get the Land Rover bits fixed and move on to the aftermarket/my mods. Not Having a go at Land Rover BTW but ........ Anyway today I removed the 2nd row seat box. There is a massive un used/un available storage area under the box, needless to say I will be making good use of this area sub, amp, inverter, extra battery's etc etc. Click image to enlarge I expect to cut out parts of the floor under the box and recess it to give more space. Click image to enlarge I also removed rear door slam catches, check out the NS body where Land Rover have had to open the holes up to get things (the catch) to line up. FFS if they made it true in the first place they would not have to carry out bodges like this later in the build OS C pillar door catch fixing holes. Click image to enlarge NS C pillar door catch fixing holes. Click image to enlarge |
11th May 2014 11:58pm |
Weston18 Member Since: 20 Oct 2013 Location: Norhamptonshire Posts: 93 |
Cant wait to see the outcome of all this work. Also how are you going to transition from the body to the tub(width wise)?
Good BUILD |
12th May 2014 1:10am |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
I'm amazed at the amount of wasted space under there!
I wonder if the 110 double cap is the same... |
12th May 2014 7:36am |
