Home > Puma (Tdci) > HELP PLEASE! Prop shaft, clunk, play |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2729 |
Yeah mines currently in the indie, being taken apart monday and he will get back with some options then (HD/genuine/ashcrofts etc etc)
Also going to check the half shafts etc while they're out incase there's too much play there which seems a common issue, but normally age/mileage related not just failure. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
21st Jun 2014 11:45am |
so cars back and running miles better now, no clunks and no slack
this was what the old diff looked like!! Click image to enlarge suspect it has been getting worse and worse for a while and one day just went and i should've realised its too clunky, but i guess its like the frogs in cold water being brought up to the boil - you don't notice gradual changes!! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
28th Jun 2014 9:59pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3618 |
David
I would say you were lucky to get that just in time, another few miles and that could have caused a serious catastrophic failure. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
28th Jun 2014 10:40pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
driver abuse Pov.spec,ftw. 2006, 110,TD5.
28th Jun 2014 10:57pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16972 |
Similar thing happened to my front diff. There are pictures in a thread somewhere on here.
I have (at last) finally got my driveline clunk free, and at the moment it is a delight to drive (there, I've jinxed it now)! All it took was a new clutch, lubricating all moving parts of the gear levers, a new transfer box, Ashcroft ATBs in both axles, and Ashcroft HD halfshafts front and rear, Ashcroft HD CV joints, and Ashcroft HD drive flanges all round. It now drives like it should! |
29th Jun 2014 11:02pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
^^ so a quick easy fix then BW!! My 109 thread
my youtube channel |
29th Jun 2014 11:19pm |
Four years and more cash than I'll admit to with SWMBO in earshot, but worth it! I'll enjoy it till the next bit breaks!
29th Jun 2014 11:46pm |
Ouch What did he do? Just put a new diff in? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
30th Jun 2014 9:48pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
My early 2012 def90 is going back under warranty due to the same problem, I'll let you know the outcome.
30th Jun 2014 11:49pm |
charlesteton Member Since: 24 Feb 2013 Location: London Posts: 40 |
2011, 110 2.4, had clunk on gear change. Had rear diff seals redone and replaced drivers side half shaft under extended warranty, now very tight and no clunk.
16th Jan 2015 9:49am |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
Can you tell by looking at the diff (without removing it) if it`s a two or four pin type. Or is it a chassis break point type thing.
I`ve got a 2011 my 90 so I assume it`s a four pin type. Excuse the spelling I`am better with spanners and wires. |
16th Jan 2015 8:28pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5442 |
Yours will be a 2 pin as it's a 90. You can tell via the diff fill hole.
Andy |
16th Jan 2015 10:18pm |
! another thing to go wrong.
Thanks Excuse the spelling I`am better with spanners and wires. |
17th Jan 2015 12:41pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
Couple of easy questions please;
Are front and rear diffs the same? And should there be the same amount of rotational slack in the front and rear props (assuming hand brake is off) ? Thanks |
27th Feb 2015 7:41pm |
