Home > Puma (Tdci) > Clutch again! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2262 |
Make sure you got the LR037956 part an not any other. I would change the spigot bearing. Fill the space with grease and give it a punch with a round tool of the same diameter (soory about my Tarzanian english). The pressure will make the bearing to move from the flange. You may need to do it several times. I would not worry about the centering tool, just use your best "eye" to center the plate. Puma 110" SW
25th Jan 2014 9:40pm |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 |
When aligning clutches I always use a 3/8 or 1/2" drive socket extension bar with a deep socket that is the best fit into the spigot. I use black tape round the socket to get a good tight but sliding fit and then again use black tape on the extension where it fits through the clutch plate to take up any gap.Aways worked for me even when having to handball the gearbox back into place without the aid of a jack when working in the field. Hope this helps!
25th Jan 2014 9:52pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
I haven't got another genuine clutch, I've got a AP driveline - formerly Borg and Beck. these seem to have good reviews. NO ROAD..........EXCEPT FOR LANDROVER |
26th Jan 2014 11:15am |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 |
The ap ones a not the best, part mk is correct.
26th Jan 2014 11:21am |
o dear. ive just had it out of the box and the springs are loose enough to turn
so really I want one of these http://www.ebay.co.uk/itm/Genuine-Defender...1#shpCntId NO ROAD..........EXCEPT FOR LANDROVER |
26th Jan 2014 11:54am |
Donīt worry about the springs. All OEM clutches are made by AP (except one made by Britpart) and have been going through some mods (main springs, central damper, thrust washers, etc). The very latest is LR048731 and LR switched back again to the part number I mentioned before.
What is the part number you have got? Puma 110" SW ............................................................. Earth first. Other planets later |
26th Jan 2014 12:25pm |
Hi the part number is LR012199G if you shake the plate the springs rattle like hell. I don't want to swap a flat tyre for a puncture, so im leaning towards this one LR037956. many thanks, Harry NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 12:32pm |
That is a genuine one but outdated. Springs are meant to rattle on all Puma clutches. You can get the OEM LR037956 at half price from any shop online. Puma 110" SW
26th Jan 2014 12:36pm |
So this is the one I want http://www.ebay.co.uk/itm/Genuine-Defender...8040025189 NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 12:44pm |
Or this one http://www.lrdirect.com/LR037956-supplied-...DRIVE.html at half the price. Puma 110" SW
26th Jan 2014 12:46pm |
Thank you very much MK you have been most helpful. I will order one of those. NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 12:50pm |
just one other thing can you clarify that this is the correct spigot bearing http://www.lrdirect.com/LR004390-supplied-...ROVER.html NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 12:59pm |
Puma 110" SW
26th Jan 2014 1:00pm |
cheers matey NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 1:29pm |
