Home > Puma (Tdci) > Clutch again! |
What a flurry of information in a short time.
MK I think you've made someone happy..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Jan 2014 1:33pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
VERY happy! NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 1:36pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2261 |
Canīt remember very well, but wasnīt hard to get it out. Now, for the whole thing is just like the old ones. Heavy as hell and a bit PITA to disconnect the hyd line running beside the Gbox close to the entry of the bellhousing (on a LHD). It is kind of tricky to remove the exhaust with the cat as it does not fit between the engine and chassis. You need to turn it and move up and down untill you find a unique position to take it down. This last part can be frustrating and worth lots of swearing against LR Puma 110" SW
26th Jan 2014 3:05pm |
thank you NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 3:15pm |
Harry if you can get a jack under the engine and apply pressure with the jack this will give you the extra 5mm you need to get the catalytic convertor out a lot easier.
With the Griffin you've got I'm surprised the cat's still there? Maybe time to bin the cat anyway perhaps? Good luck. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Jan 2014 3:33pm |
no cat under there, he's long gone! NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 3:35pm |
Mine too. Meeeooowww....No more!!!!! If you go through life with your head in the sand....all people will see is an ar5e!!
26th Jan 2014 3:37pm |
well..... all bits ordered, just need the postie to deliver them now NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 9:28pm |
can you throw a picture of the findings? Puma 110" SW
26th Jan 2014 9:53pm |
I sure can, wont be till next weekend though NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 9:56pm |
I guess this is not the first swap? Puma 110" SW
26th Jan 2014 10:28pm |
its the second one its had, 1st under warranty it didn't rattle till about a week or 10 days since, then the other night it just went, so I'm wondering if 1 of the springs has come out and is wedged which is stopping the clutch disengaging. no doubt i'll find out NO ROAD..........EXCEPT FOR LANDROVER
26th Jan 2014 11:10pm |
what's the best method of removing the spigot bearing? NO ROAD..........EXCEPT FOR LANDROVER
29th Jan 2014 3:20pm |
There is a (LR) special tool for it. Otherwise you need to use the old "bread or grease" method (google it). Puma 110" SW
29th Jan 2014 4:04pm |
