Home > Puma (Tdci) > Towing options |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1568 |
I use the adjustable find it very useful. Easy to set level when towing different trailers.
The step mounted one looks great. But us very high even more so if your getting a 110. I use a ball and pin Dixon and bate. So there's not a lot I can't tow. |
31st Oct 2013 8:54am |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2725 |
Yeah if I were you if go for an adjustable towing bar and ball/jaw (like this http://item.mobileweb.ebay.co.uk/viewitem?...582127052)
And lucky you in the position you are! Maybe a remap to help with the towing too? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
31st Oct 2013 9:28am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
I've had the genuine adjustable tow bar on my last two 110s with a Dixon Bate hitch (swop to a NATO on a spare slider if needed) and I find it the best set up. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
31st Oct 2013 11:42am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16943 |
If you tow a variety of trailers then there is nothing at all better than the Dixon-Bate adjustable arrangement. Different heights and different couplings are a doddle.
The bottom of the bracket is possibly a bit low, and if you offroad you'll get used to the "thud" as it grounds, but in 30+ years of using them including extensive off-road I have never had any problems. |
31st Oct 2013 11:49am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Same as everyone else above
Adjustable droplate 6 bolts and it off California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
31st Oct 2013 12:49pm |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 |
Cheers guys - looks like the adjustable is the way to go (and good tip about having a spare plate!).
This appears to be dealer fit option (and I'm assuming electrics aren't included in the price?) - does anyone know roughly how much fitting is likely to be (or is it normally thrown in)? From posts on here the bar itself looks like an easy DIY job, but routing the electrics looks to be a bit of a PITA. As for being lucky... couldn't agree more. Never been in a position to factory order a vehicle before so really looking forward to getting exactly what I want this time. |
31st Oct 2013 12:53pm |
There was a post on here, in the last few days about finding the plug to connect up the electrics,, easy job
Whole lot can be fitted under the hour As my bar comes off regularly, i have fitted the electric socket into the crossmember,, save's removing it when taking the bar off California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
31st Oct 2013 12:59pm |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 |
This is my solution for an adjustable tow ball.
Click image to enlarge DEFENDER XS UTILTY 110 AUTO ONLY ACCURATE GUNS ARE INTERESTING |
31st Oct 2013 1:09pm |
rover Member Since: 26 May 2012 Location: Yorkshire Posts: 146 |
From my experience with the 110 2.2 you will definately need a remap for towing. In the lower gears torque is restricted and makes the whole driving experience hard work. My old TD5 was much better in first and second.
Problem with the remap is it will void the warranty and you can not get a switchable one at the moment so to be on the safe side you need two ECU's. Sorry to put a dampener on things. What are other peoples experience with the 2.2 and torque in lower gears, I must admit the 110 I had on the land rover experience was much smoother and seemed more powerful then mine. It has crossed my mind whether the land rover experience defenders have had a mild remap. |
31st Oct 2013 1:10pm |
I think I've seen similar before - leaving the ball in, it looks like it protrudes a good way from the back of the vehicle?
I'll look that one out. The one I saw seemed to suggest it was a several hour job... and socket into the crossmember looks neat. As for remap, I think it'll probably be a case of seeing how it goes at first. Always a little reluctant to go down that route, especially until a map's been in use for a good while (which I'm not sure they will have been for these?). |
31st Oct 2013 1:43pm |
It' fairly easy to fit and with correct loom the electrics are straight forward. Mine electrics were fitted as part of the deal with a rear step tow bar as I thought I'd try that. I sold the tow step after a short time and fitted the adjustable kit from my old 07 as the step didn't give me the same flexibility. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
31st Oct 2013 1:47pm |
Sonarmender Member Since: 04 Apr 2013 Location: Guz Posts: 338 |
No remap and a big twin axle caravan, no problem, infact it pulls like a train You only have one life, live it....forget the cost.
90XS Hardtop |
31st Oct 2013 2:02pm |
Way too low if you ever need to tow an ex-military trailer fitted with a 76mm NATO lunette though. The best place for the socket (assuming that you only need one) is the recess in the crossmember, which is provided for ... let me see.... ah yes, the trailer socket! |
31st Oct 2013 2:10pm |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 855 |
Why adjustable? Are you going to be towing a variety of trailers? The only thing I tow is a two-tonne boat on a twin axle trailer, on a standard towbar the centre of the ball of a Dixon Bate towball and jaw is 50cm/20” off the ground with the vehicle unladen, possibly a bit high for a small trailer but perfect for me.
And the electrics? Although my boat trailer is only 7-pin, I’ve a 13-pin on the truck; better to go for the more “modern” installation and use a 13 to 7 adapter. Peter |
31st Oct 2013 2:12pm |
