Home > Technical > THE webasto Thread |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7710 |
its done and it works! Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
19th Oct 2012 5:21pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
We cannot compete with some of the pricing on Thermo top C's you guys find but do have an alternative for Puma mounting which is under the n/s wing on RHD cars using our own custom bracket
19th Oct 2012 9:50pm |
A - When the heater is ALL OFF the cooling water enter from "3" and go directly to the "4" (no flow on heater). B - When the heater is ALL ON the cooling water enter from "3" and go trough "2", heater matrix, "1" and, at least, return t the engine circuit "4". In the "middle" regulation is a "mix" of A and B is it clear? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
19th Oct 2012 9:56pm |
When I studied my installation I tried the same possibility also, but no room here for LHD Puma (clutch pedal/pump). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
19th Oct 2012 10:04pm |
thats where mine has just been fitted. bloody tight on the intake cowl though. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
19th Oct 2012 10:49pm |
James - make sure you leave enough room behind the wing - as you know these units get hot
20th Oct 2012 8:11am |
yes, but on LHD you can use BMW X5 installation kit ... like I did |
20th Oct 2012 8:12am |
Have you photos/infos? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
20th Oct 2012 8:15am |
theres about a 30mm air gap around it, seems ok so far! Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
20th Oct 2012 9:18am |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
um think i've got the wrong dip tube for the tank.
what have you fitted? mines 300 mm long? seems to short. The loom i ordered from Turkey off Ebay along with a few other bits has arrived. Very good service. So far i've spent £180. i have a second set of plugs to make another loom. this is great! |
20th Oct 2012 5:01pm |
i ordered the one off the link posted before, i had to cut 1/3 - 1/2 of it off. Cheers
20th Oct 2012 8:03pm |
https://sales.butlertechnik.com/vehicle-he...-41s45017a
i used this one. you may get away with a 300mm one, i can measure how much i cut off! have the ends but cant remember how much i left on. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
20th Oct 2012 8:05pm |
just to say the thermo top C has been in since Sat and i am very pleased with it.
with 9 deg amb and no internal heating, 20mins or just under brings it up to 58 deg or so, i have mine plumbed to heat the block first and it works for what i want. Airtop has been in for 10 days now (ish) and is working a treat, i may move the air intake (comb side) at one point, but it will suffice for now. Just to say a big thank you to everyone on here for their help and advice in the fitting, greatly appreciated. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
23rd Oct 2012 8:06pm |
good day today. dropped tank, fitted line and pump. tried to fit loom and webasto bit failing light and enthusiasm beat me.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge easy enough although i did have a moment when the fuel gauge wouldn't go back up did after 30 seconds loom to fit and webasto unit. |
27th Oct 2012 8:27pm |
