Home > Maintenance & Modifications > Fitting Roof Rack Spot Lights - Puma 110
Page 2 of 6 <123456>
BruceT
South Africa
FG, how did you run your wiring to the roof?
Post #126342 24th Feb 2012 10:51am
FG
Sweden 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Well, seeing as the Defender normally is about as watertight as your everyday collander, why not go straight through the roof?! Shocked
Joking aside, it has actually worked so far. Last four weeks a steady load of about five inches of snow and ice on the roof and no leaks. I did use a special two piece watertight plug to go through though, topped up with plenty of bathroom sealant.
Boy's installation make me jealous though, a real top job! Thumbs Up would anybody know how many amps is safe to run through the high beams without burning the assy out?
/FG
Post #126578 25th Feb 2012 9:13am
BruceT
South Africa
Fited the lights this weekend but kept them low due to the amount of bush driving I do. Ran the wiring down the snorkel. Just need to get the LR Aux 2 switches, so I have temporary switches in currently.
I would attach a picture if I new how. Question
Will keep trying.
Does anyone know the part numbers for the switches and plugs?
Thank you
Post #127000 27th Feb 2012 10:20am
PaulMc
Will keep trying.
Thank you
Switches are YUG000540LNF -
http://www.rimmerbros.co.uk/Item--i-YUG000540LNF
http://www.brit-car.co.uk/product.php?xProd=95259
http://www.lrseries.com/shop/product/listi...WITCH.html
Black Connector here -
http://www.ebay.co.uk/itm/160732950338
Wired like this -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #127300 28th Feb 2012 12:11am
v40mav
What's the best way to secure the cable to the pins crimp or solder .
Is there a separate crimp tool for these connectors. Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #127302 28th Feb 2012 12:24am
PaulMc
Crimping is the correct way to do these terminals.
The terminals won't go into the connector housing if the tabs aren't crimped down.
I use one of these -
But you can do a reasonable crimp with one of these (TT70) -
http://www.polevolt.co.uk/acatalog/info_TT70.html
Post #127306 28th Feb 2012 12:37am
BruceT
South Africa
Wow great service here. Laughing
Thank you Paul. Appreciate all the help.
Post #127316 28th Feb 2012 6:45am
v40mav
Thanks. I suspected that would be the case. Now to get a decent set Very Happy
One additional question.
I'm looking for a selection of waterproof connectors. Are there any other recommended suppliers other than VWP. Defender 110 County SW
Disco 3 HSE
Post #127319 28th Feb 2012 7:21am
RS-Online Thumbs Up I find VWP stuff cheap at times
A good alternative to Rennsteig is Knipex Mr. Green
Post #127321 28th Feb 2012 7:30am
v40mav
Cheers Ken
I can never seem to find what I want on RS Online unless I have a code. Must try again and be more patient when looking.
Knipex totally agree with quality kit. I have a selection of the standard pliers in the toolbox form them and had these for years great quality. Very Happy Defender 110 County SW
Disco 3 HSE
Post #127326 28th Feb 2012 7:55am
PaulMc
RS are good if you want a quantity of something, as most things are sold in bags of 5, 10, 25, 50 or 100 (and more!).
To take as an example, a popular automotive sealed connector - the 2-way Econoseal.
From RS you have to buy -
Connector housing - Bag of 5
Terminal anti-backout - Bag of 10
Female terminals - Bag of 25
Wire seals - Bag of 25
That's just for the female connector, then you have the same again for the mating male connector (the wire seal is the only part in common between the two)
And, of course, you have to know all of the Tyco/AMP or RS part numbers.
A much easier alternative, is to buy them from Polevolt (who are cheaper than VWP - and RS Shocked ) -
http://www.polevolt.co.uk/acatalog/info_ESC2F.html
Price each: £1.42 (£1.70 Including VAT at 20%)
http://www.polevolt.co.uk/acatalog/info_ESC2M.html
Price each: £0.95 (£1.14 Including VAT at 20%)
I've no connection with Polevolt, other than as a satisfied customer Thumbs Up
. Paul.
Post #127341 28th Feb 2012 9:19am
v40mav
Thumbs Up
thanks Defender 110 County SW
Disco 3 HSE
Post #127344 28th Feb 2012 9:25am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I always try to crimp then solder but with those it is VERY hard to do becasue if you use too much solder or over lap the profile of the metal pin/connector it will not clip into the pastic housing.
Post #127353 28th Feb 2012 9:37am
Paul great advice Thumbs Up
For my sins I have to buy in bulk Big Cry
Post #127368 28th Feb 2012 10:18am
The Boy
Thanks for that PoleVolt link Paul. Bow down
have saved it and when I get a moment I will have a good look through as i want some body flush plugs for something Thumbs Up
Post #127374 28th Feb 2012 10:56am
