Home > Maintenance & Modifications > Fitting Roof Rack Spot Lights - Puma 110
Page 5 of 6 <123456>
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Spotted the rectangular grommets yesterday evening - was looking for round ones lower down Rolling Eyes
I don't really want to cable tie around the RAI - has anyone tried adhesive cable tie mounts, will they take the punishment? My Disco 'best bits'
Defender 110 XS CSW 2013
Post #261323 26th Aug 2013 7:56am
BruceT
South Africa
I like the idea of adhesive cable ties.......another idea for you...i have a friend who ran his cables on the inside of his snorkel. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #261324 26th Aug 2013 7:57am
DiscoStu
Ah, that's an idea Thumbs Up My Disco 'best bits'
Post #261330 26th Aug 2013 8:58am
Myo
South Africa 2010 Defender 90 Puma 2.4 CSW Stornoway Grey
So I want to install a light bar to my soft A frame. The wiring should be about the same, but I chickened out and got a KC Highlights loom Very Happy I don't think I have the patience to make one from scratch!
Where would I run the cable to the light bar through the bulkhead? There's a rubber seal on the bulkhead left hand side, accessible from the panel below the passenger side dash, can I use this? How would I go about sealing this?
I'm thinking maybe I should post some pics, as soon as I figure out how...
Post #306052 7th Feb 2014 11:08pm
Cold_n_Wet
Norway
The G4's ran the cables through the snorkel, I just cabled tied on my 06, but not sure what I am going to do on the MY13, I don't have a snorkel yet.
I want to have the option to remove the rack (all though I may never do it).
I could run a couple of high current feeds to the roof rack, and low curent switch connectors and mount the relay pack under the roof rack in an water resistant box, but it would be a PITA to trouble shoot. "Rafiki" 2007 110 STW - Rolling rebuild.
Post #306082 8th Feb 2014 2:35am
Piratepaul
United Kingdom 1989 Defender 110 200 Tdi SW Baltic Blue
THE BOY, where did you get your external visor from, look good
Post #312227 28th Feb 2014 2:38am
K9F
Yours is a very similar arrangement to my own. I decided to keep everything in one place and mounted the whole 'kit and kaboodle' in an IP rated enclosure. I also used DIN rail and Wago terminals to prevent soldering and heatshrinking cables but fitted bootlace crimps to go inside the Wago instead. I also dislike the standard automotive relays and sourced DPDT Releco 12v relays as they are so much more versatile with an internal LED to indicate when activated and a test facility to operate the relay without a triggering signal.
The Boy wrote:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #312336 28th Feb 2014 2:29pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
So tidy Surprised
Makes me feel bad..
Post #312388 28th Feb 2014 5:51pm
K9F
Are you an electrician by chance? I am and mine looked worse than yours. Laughing Reminds me of the fact most builders houses look like a building site.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #312400 28th Feb 2014 7:04pm
Myo
[quote="Myo"]So I want to install a light bar to my soft A frame. The wiring should be about the same, but I chickened out and got a KC Highlights loom Very Happy I don't think I have the patience to make one from scratch!
I'm thinking maybe I should post some pics, as soon as I figure out how...[/quote]
Post #312809 2nd Mar 2014 9:31am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
PaulMc wrote:
Wired like this -
Any idea what is the color of wire that goes to "+12V dash illumination" to tdci ?
Can I connect it direct to +12V battery instead of dash?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  www.newfoundland.gr
Post #318561 23rd Mar 2014 11:20pm
PaulMc
Don't connect it to "+12V Battery" - otherwise the switch will be permanently illuminated.
The dash illumination on a Tdci is - Red/Orange (Red with an Orange trace)
This can be picked-up at an adjacent switch, or from circuit header C0286 (on a LHD vehicle) behind the centre dash facia.
. Paul.
Post #318570 23rd Mar 2014 11:34pm
pouf
Thank you very much Paul!
And what about this little blue/orange cable??
Says that I have to connect it with the same at the dash but I can't fint it… Confused www.newfoundland.gr
Post #318619 24th Mar 2014 9:32am
PaulMc
Blue/Orange is usually the RH main beam circuit.
Where does your pictured Blue/Orange cable come from Question
What instructions are you following Question
. Paul.
Post #318651 24th Mar 2014 12:06pm
pouf
It comes from 85 relay
I use fitting instruction No 53208 www.newfoundland.gr
Post #318659 24th Mar 2014 12:45pm
