Home > Technical > ATB (torsen) front and rear install |
Given your location as long as the unit is in good nick then I would jump on that. |
12th Apr 2024 10:10am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2618 |
^ And so I did!
Got it fitted, and straight away noticed the following: - the steering is a lot heavier - there is a lot more understeer now - the steering doesn't return to centre as quickly Oh well, gone are the days of slinging it around the many traffic circles in town then -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
26th Apr 2024 8:53am |
Never fear Naks it does improve a lot Give it time and you'll find that the ATB will loosen up a bit and the understeer will reduce and the steering lighten. Or you will grow bigger muscles
26th Apr 2024 9:39am |
At full lock, e.g., turning in & out of a parking bay, there's some grabbing - is that normal? Any way to dial it back a touch? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
26th Apr 2024 12:32pm |
^ turns out that the workshop forgot to refit the turn stoppers --
29th Apr 2024 8:24am |
As in the steering stops on the swivel housings?
30th Apr 2024 7:56pm |
^ yep, those very same ones. no wonder the tyres were grabbing at full lock.
took it back, and they fitted them on the spot, and adjusted the handbrake as well, it was clanking at low speeds. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
1st May 2024 8:19am |
Did a trail this weekend, it was raining quite a bit, so slippery gravel/rocks.
Not sure the front ATB made a big difference, TBH... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
6th May 2024 8:19am |
While investigating a clunk in the rear diff when taking off from standstill, this is what we found:
https://www.reddit.com/r/LandRoverDefender...r_6_years/ there was also no play at all on the crown when cold, so it was eating the rear side shafts. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ Last edited by Naks on 7th Jun 2024 9:00pm. Edited 1 time in total |
7th Jun 2024 8:07pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16979 |
Unfortunately whatever is in your link requires the installation of an "app" (which I have no intention of doing) and is not viewable without.
7th Jun 2024 8:53pm |
odd, it's just a reddit link --
7th Jun 2024 9:00pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2285 |
Any clues why this happened?
It can be fixed I reckon Puma 110" SW ............................................................. Earth first. Other planets later |
7th Jun 2024 9:02pm |
dunno, I started experiencing a clunk when driving from standstill, so this is what led us here.
This Ashcroft ATB was installed in August 2017, and has done about 24,000km. So I guess the bearings eventually got loose enough to start causing the issue? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
7th Jun 2024 9:05pm |
