Home > Puma (Tdci) > Washer jets |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2059 |
But it’s small…
Click image to enlarge |
10th Nov 2023 8:09pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
7 years on the website has changed, so here's the current URL for the relay: https://www.mudstuff.co.uk/products/defend...&_ss=r |
14th Nov 2023 6:26pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 996 |
Just search for "Volkswagen Wiper Relay 99". Plenty of offers new and used.
14th Nov 2023 9:26pm |
Learningasigo Member Since: 30 Nov 2023 Location: Midlands Posts: 27 |
During some light winter maintenance I tried to unblock my front washer jets. A needle didn’t help and in fact only made it worse. I used some compressed air (dust/air in a can) and sprayed directly into the nozzle. This worked an absolute treat and cleared both with easy using only a few seconds of air. Both worked fine for a short while….
I remember recalling the sound of air escaping in the bonnet during the clearing but assumed it was a straight feed to the pump and was probably some sort of expansion valve. The system is now best described as ‘limp’. I haven’t seen any washer fluid leaking underneath, nor is the washer bottle empty. I wonder if I have blown the non-return Thanks for any advice or possible areas to check for damage. |
1st Dec 2023 7:53am |
See reply in Technical section 👍
1st Dec 2023 7:59am |
GuJa Member Since: 03 Oct 2017 Location: Elsfleth Posts: 19 |
Well, I used the Pierburg too but had to change it also after one year. Why? See picture. It seems there is a difference between water and diesel or petrol
1st Dec 2023 10:46am |
ahh, rust..., who would've thought - I certainly didn't
I forgot to open mine before binning it, so thanks. |
1st Dec 2023 4:23pm |
