|  | Home > Maintenance & Modifications > Side light just started to flicker |
| revd Member Since: 20 Apr 2024 Location: England Posts: 308    | Swap side to side
 If the same lamp still flickers then it is the lamp If the swapped over light flickers then it is an earth/wiring problem | ||
|  17th Oct 2025 9:08am |
| Fellrunner Member Since: 28 Sep 2014 Location: Wandering Posts: 261      | Well that's a brilliantly simple and logical suggestion.  Thank you!    | ||
|  17th Oct 2025 10:15am |
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1373      | Flickering is most likely an issue with the LED driver electronics inside the light. There are a bunch of you tube channels where people take this stuff apart and analyse the circuit and components and often they find cost cutting measures that significantly shorten the lifespan. Obviously all is fine within the warranty period.
 I had a lot of these 12v LEDs go bad on me, including once a set of brake lights! Scary. You can try to buy branded hopefully quality parts or revert back to incandescent bulbs. Or just accept you need to regularly check and might need to change them out occasionally | ||
|  17th Oct 2025 11:17am |
| Fellrunner Member Since: 28 Sep 2014 Location: Wandering Posts: 261      | Thanks @TexasRover | ||
|  17th Oct 2025 4:01pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
