![]() | Home > Td5 > Heater blower voltage drop |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138 ![]() ![]() ![]() |
Not sure about the Td5 but the Puma's blower takes about 8 amps on 2 and 13 on full. This could indeed cause a significant voltage drop. Without the engine running that is.
Heat or not is not related to the blower circuit. |
CdnGriff Member Since: 27 Jul 2025 Location: Ontario Posts: 8 ![]() ![]() ![]() |
Thanks, this is with the engine running. TD5 10p version.
I understand the heat is a totally different problem. 1999 Defender 90 S/W |
