Home > Td5 > Heater blower voltage drop
CdnGriff
Canada 1999 Defender 90 Td5 CSW Keswick Green
Hey all,
When the fan is on "2" or full, my voltmeter takes a serious dive into the low 12s from high 13/low 14v
Is this normal?
I just had to replace the battery so I'm suddenly very observant of those fun little numbers flickering from my cigar lighter meter.
There's also zero, and I mean zero heat, but I need to replace the bonnet cable so I can get into the heater box to take a look. Waiting for part. 1999 Defender 90 S/W
Post #1077613 15th Oct 2025 7:02pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Not sure about the Td5 but the Puma's blower takes about 8 amps on 2 and 13 on full. This could indeed cause a significant voltage drop. Without the engine running that is.
Heat or not is not related to the blower circuit.
Post #1077625 15th Oct 2025 8:35pm
CdnGriff
Thanks, this is with the engine running. TD5 10p version.
I understand the heat is a totally different problem. 1999 Defender 90 S/W
Post #1077646 15th Oct 2025 10:09pm
