Home > Technical > Erratic Signal Front Left Wheel Speed Sensor
HardCharger
Hi All!
After my truck rebuild, I've been driving him around and every now and then ABS would kick in when stopping and sometimes traction control will also kick in if I applied some throttle when in first gear. Last Saturday, both the ABS & TC light came on but the truck drove normally and had no issues / dramas. After a while, the lights went off and the ABS & TC started doing their thing again.
I plugged in my GAP IIDTool BT when I got home and it give me the Fault ABS-Brake Module, C0031-2F (A8 ) Front Left Wheel Speed Sensor - General Signal Failure - Signal is Erratic.
My mechanic sais to buy a new wheel speed sensor. He also said that while we were at it, I should buy two so we can preemptively change out the right front wheel speed sensor as well. I'm about to order them but would still like to know what all y'all think. Thanks in advance! Thumbs Up No Better Friend, No Worse Enemy
Post #1075889 22nd Sep 2025 8:30am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
I would only change the left sensor. I see no point in changing the right one.
Since the problems started after a rebuild, could it be that the sensor is not sufficiently inserted?
Post #1075895 22nd Sep 2025 9:21am
HardCharger
Hi Johan_B,
We figured the other sensor might miss his buddy and decide to pack up as well Rolling with laughter
Will have them check about the insertion of the sensor, but just to be on the safe side I already ordered the parts. On the bright side, the front sensors will now be new and I have a spare for just in case. Thumbs Up
Now I just hope the rear sensors play along and not give me problems until maybe the next rebuild some 20 to 30 years down the line Mr. Green No Better Friend, No Worse Enemy
Post #1075951 23rd Sep 2025 1:31am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I had a similar problem after i changed my brake pads, discs and front left stub axle. Checking the speed sensor reading in my diagnostic machine pointed to the front left wheel not matching the other wheel speeds. I bought a new sensor but it turned out that the original sensor needed pushing back down into the hub a little bit. 1953 80"
1987 mini city e
2011 90"
Post #1076002 23rd Sep 2025 7:00pm
HardCharger
Hi Mr_James,
Thank you for that!
Now, is this a simple matter of loosening a nut, pushing sensor further in, retighten nut and done? The parts I ordered are supposedly going to arrive by end of day tomorrow but I can't get a schedule with my mechanic until some time Wednesday next week so I thought to try and do the simple thing first and see if that solves the problem. I'm also afraid that if I wait too long, the problem may give birth to other problems and that's the last thing I need right now. No Better Friend, No Worse Enemy
Post #1076030 24th Sep 2025 3:30am
Screbble
They are ‘push’ in Thumbs Up
Post #1076044 24th Sep 2025 7:46am
Johan_B
If I remember correct you just push the sensor in, no screws holding it in place. The advice I received was to push it all the way in until it couldn't go any further, and then gently turn the hub which would cause the pulse ring on the CV joint to push the sensor out if there was interference.
Post #1076051 24th Sep 2025 9:16am
HardCharger
Hi Johan_B & Screbble,
Thank you for the advice.
I actually tried to push them in yesterday but didn't really have the leverage position so it didn't budge. Whistle Will try again probably on Saturday when I have a bit more time and help to try and sort it. Thumbs Up No Better Friend, No Worse Enemy
Post #1076123 25th Sep 2025 4:33am
MR_JAMES
Mine was a bit difficult to push down, but where the wire goes into the silver sensor there is a raised section which enabled a spanner to be slid on. wiggling the spanner and pushing down at the same worked for me. 1953 80"
1987 mini city e
2011 90"
Post #1076263 26th Sep 2025 9:11pm
Screbble
The sensor sits inside a copper cage which sits in the machined aperture in the hub casting.
You can twist the sensor carefully to try and move in further down.
Be careful not to break the top where the cable enters.
Post #1076289 27th Sep 2025 10:14am
HardCharger
Thanks for that, Screbble.
Will take note of the the copper cage part number, just in case. Still waiting on the sensors I ordered as there were a few storms that passed by locally and delayed delivery. Hoping to get them today but may not be until tomorrow then probably on Friday, going up to the mechanic to have it done while having a few things checked and sorted.
Actually cleaned and reseated the sensors and that seemed to do the trick for a while but then the ABS/TC issues came back but not as frequent and not as violent now. So I guess I was on the right track to order the sensors. No Better Friend, No Worse Enemy
Post #1076445 29th Sep 2025 8:16am
HardCharger
Spent yesterday figuring out why I still had the error after changing out the sensor. ABS/TC not coming on as much but the ABS and TC lights kept turning on.
Had to drive around a couple of times with the live values on display but still couldn't see anything wrong. Got an extra pair of eyes to look at the readings and used a different scanning tool to see that there was a slight delay on that particular sensor.
Dismantled that hub and saw that they CV was covered in the one shot grease which was thinner than what we expected. Cleaned it out the CV, repacked with grease, only to discover the needle bearing on the stub axle was also kaputt. Luckily, the mechanic had a stub axle with a bearing so we we got the bearing and put everything back together. Now works normally.
On the plus side, the old sensors are now very functional spares. Will now have to get stub axle bearings and seals for all four corners for future replacement once the next service rolls around. No Better Friend, No Worse Enemy
Post #1077033 8th Oct 2025 2:47am
Johan_B
Great that you found the problem! And very good with a report back for future reference.
Would there be a way to diagnose a faulty needle bearing without dismantling the hub and the stub axle?
Post #1077039 8th Oct 2025 7:48am
HardCharger
Thanks, Johan_B!
Finding the problem and fixing it was very satisfying especially after how much I threw into the rebuild. We did overlook the stub axle bearings as they were fine but decided to go out anyways. No way to tell if they've gone bad as far as I can tell. We only found mine was kaputt when analyzing the problem with the CV and double checked everything as they went back in. That's when we saw the bearing was first thought missing but was actually kaputt. Very fortunate for me they had that stub axle with the bearing still very much intact. All we had to do was clean out the dirt and grime that had accumulated on it. No Better Friend, No Worse Enemy
Post #1077110 9th Oct 2025 7:46am
