![]() | Home > Technical > Erratic Signal Front Left Wheel Speed Sensor |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 159 ![]() ![]() ![]() |
I would only change the left sensor. I see no point in changing the right one.
Since the problems started after a rebuild, could it be that the sensor is not sufficiently inserted? |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 815 ![]() ![]() ![]() |
Hi Johan_B,
We figured the other sensor might miss his buddy and decide to pack up as well ![]() Will have them check about the insertion of the sensor, but just to be on the safe side I already ordered the parts. On the bright side, the front sensors will now be new and I have a spare for just in case. ![]() Now I just hope the rear sensors play along and not give me problems until maybe the next rebuild some 20 to 30 years down the line ![]() |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270 ![]() ![]() ![]() |
I had a similar problem after i changed my brake pads, discs and front left stub axle. Checking the speed sensor reading in my diagnostic machine pointed to the front left wheel not matching the other wheel speeds. I bought a new sensor but it turned out that the original sensor needed pushing back down into the hub a little bit. 1953 80"
1987 mini city e 2011 90" |
Hi Mr_James,
Thank you for that! Now, is this a simple matter of loosening a nut, pushing sensor further in, retighten nut and done? The parts I ordered are supposedly going to arrive by end of day tomorrow but I can't get a schedule with my mechanic until some time Wednesday next week so I thought to try and do the simple thing first and see if that solves the problem. I'm also afraid that if I wait too long, the problem may give birth to other problems and that's the last thing I need right now. No Better Friend, No Worse Enemy |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347 ![]() ![]() ![]() |
They are ‘push’ in
If I remember correct you just push the sensor in, no screws holding it in place. The advice I received was to push it all the way in until it couldn't go any further, and then gently turn the hub which would cause the pulse ring on the CV joint to push the sensor out if there was interference.
Hi Johan_B & Screbble,
Thank you for the advice. I actually tried to push them in yesterday but didn't really have the leverage position so it didn't budge. ![]() ![]() |
Mine was a bit difficult to push down, but where the wire goes into the silver sensor there is a raised section which enabled a spanner to be slid on. wiggling the spanner and pushing down at the same worked for me. 1953 80"
The sensor sits inside a copper cage which sits in the machined aperture in the hub casting.
You can twist the sensor carefully to try and move in further down. Be careful not to break the top where the cable enters. ![]() Click image to enlarge |
Thanks for that, Screbble.
Will take note of the the copper cage part number, just in case. Still waiting on the sensors I ordered as there were a few storms that passed by locally and delayed delivery. Hoping to get them today but may not be until tomorrow then probably on Friday, going up to the mechanic to have it done while having a few things checked and sorted. Actually cleaned and reseated the sensors and that seemed to do the trick for a while but then the ABS/TC issues came back but not as frequent and not as violent now. So I guess I was on the right track to order the sensors. No Better Friend, No Worse Enemy |
Spent yesterday figuring out why I still had the error after changing out the sensor. ABS/TC not coming on as much but the ABS and TC lights kept turning on.
Had to drive around a couple of times with the live values on display but still couldn't see anything wrong. Got an extra pair of eyes to look at the readings and used a different scanning tool to see that there was a slight delay on that particular sensor. Dismantled that hub and saw that they CV was covered in the one shot grease which was thinner than what we expected. Cleaned it out the CV, repacked with grease, only to discover the needle bearing on the stub axle was also kaputt. Luckily, the mechanic had a stub axle with a bearing so we we got the bearing and put everything back together. Now works normally. On the plus side, the old sensors are now very functional spares. Will now have to get stub axle bearings and seals for all four corners for future replacement once the next service rolls around. No Better Friend, No Worse Enemy |
Great that you found the problem! And very good with a report back for future reference.
Would there be a way to diagnose a faulty needle bearing without dismantling the hub and the stub axle? |
Thanks, Johan_B!
Finding the problem and fixing it was very satisfying especially after how much I threw into the rebuild. We did overlook the stub axle bearings as they were fine but decided to go out anyways. No way to tell if they've gone bad as far as I can tell. We only found mine was kaputt when analyzing the problem with the CV and double checked everything as they went back in. That's when we saw the bearing was first thought missing but was actually kaputt. Very fortunate for me they had that stub axle with the bearing still very much intact. All we had to do was clean out the dirt and grime that had accumulated on it. No Better Friend, No Worse Enemy |
