Home > Puma (Tdci) > Boost pipe leaking..?
Gal Dove
Wales 2014 Defender 110 Puma 2.2 USW Corris Grey
Hi all.
Puma 2.2. MY 2014. 31k miles.
I've got a 'air-sucking' sound coming from the n/s when under power - nothing at idle.
I'm assuming that it's one of the boost hoses - and most likely to be the one that sits under the EGR valve and has a tight 90deg turn in it towards the front of the car. Engine Management light is now on too.
I've done a bit of searching on here to try and get some advice on fitting and whether to go with OEM or silicone, etc.
Can anyone confirm that I'm probably in the right ballpark in terms of diagnosis - and if so whether there's any advice on what hoses to replace the busted one with (OEM/silicone?) - and how difficult the job is likely to be? Pretty shocked that this has happened on a 2014 car with 31k miles! Many thanks.
Post #1075708 18th Sep 2025 9:06pm
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hey, I have a n sucking noise on mine too 2.2 110 2015 60k. I always thought it was normal for the 2.2 when the window is open. But then I dont have the Engine Management light aswell.
Do you have a code reader? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1075743 19th Sep 2025 4:34pm
Gal Dove
Hi Andy.
Thanks. No, I don’t have a code reader but there was a hole in the 90° boost pipe - so it’s definitely knackered.
My engine management light took a while to come on. You’d be losing power under acceleration if you’ve got a hole. She’ll only do it whilst moving and under acceleration.
Post #1075759 19th Sep 2025 8:03pm
Crash7
Did you go silicone or OEM replacement?
Post #1075765 19th Sep 2025 9:09pm
Gal Dove
Good question. I was caught out by this and didn’t realise that silicone was and option. I’ve only ever seen this on fast German cars with the engine in the back Very Happy
So it looks like it’ll be OEM - or worse still, aftermarket.
Post #1075766 19th Sep 2025 9:18pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Hi Gal
Have a look here for instructions to change the elbow https://www.defender2.net/forum/topic81674.html. It’s quite a common failure unfortunately but there are some good quality silicone replacements available which last far longer than the original LR ones.
Post #1075774 20th Sep 2025 12:28am
Gal Dove
That's great, many thanks, piechipsandpeas Thumbs Up
Post #1075806 20th Sep 2025 5:12pm
