![]() | Home > Puma (Tdci) > Boost pipe leaking..? |
Andyslandytd5 Member Since: 06 Nov 2021 Location: Southampton Posts: 91 ![]() ![]() ![]() |
Hey, I have a n sucking noise on mine too 2.2 110 2015 60k. I always thought it was normal for the 2.2 when the window is open. But then I dont have the Engine Management light aswell.
Do you have a code reader? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
Gal Dove Member Since: 22 Jan 2022 Location: South Wales Posts: 87 ![]() ![]() ![]() |
Hi Andy.
Thanks. No, I don’t have a code reader but there was a hole in the 90° boost pipe - so it’s definitely knackered. My engine management light took a while to come on. You’d be losing power under acceleration if you’ve got a hole. She’ll only do it whilst moving and under acceleration. |
Crash7 Member Since: 21 Feb 2024 Location: South Posts: 43 ![]() ![]() |
Did you go silicone or OEM replacement?
Good question. I was caught out by this and didn’t realise that silicone was and option. I’ve only ever seen this on fast German cars with the engine in the back
![]() So it looks like it’ll be OEM - or worse still, aftermarket. |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 235 ![]() ![]() ![]() |
Hi Gal
Have a look here for instructions to change the elbow https://www.defender2.net/forum/topic81674.html. It’s quite a common failure unfortunately but there are some good quality silicone replacements available which last far longer than the original LR ones. |
That's great, many thanks, piechipsandpeas
