![]() | Home > Td5 > Td5 Startup Thumping Noise |
DefenderCan Member Since: 25 Nov 2023 Location: Canada Posts: 47 ![]() ![]() ![]() |
Good morning All,
My first post..... Was hoping for some help on a noise I have on startup. When I start my truck up, I get a somewhat thumping noise that will last about 20 seconds max then stops instantly. If I drive without letting the noise stop it turns into a tick but stops after a few feet of driving. It will never come back throughout the drive. It doesn't thump all the time, never when hot. The noise matches the revs when accelerating. I am really tempted to pull the injectors and renew the seals and washers, but I have no solid evidence those are the culprit. Here is a link to the startup noise and you can hear it stop, https://youtube.com/shorts/mIzpUjs0Ml4?feature=shared If i don't let the noise stop, and drive a bit it will turn into a tick, in this video it is hard to hear, https://youtube.com/shorts/xL946srOG78?si=yd-eMZ7PFr6bd0pY So, this is my diagnostics so far, No smoke from exhaust, all plugs are dry, truck has 175,000km, oil level hasn't risen, coolant reservoir has no oil. I have dumped fuel additives with no help, and I run shell diesel and no blowby. It isn't too concerning as the truck runs fine, feels strong and I don't have any really concerning symptoms only the noises I hear. I am thinking possibly a burnt valve seal or possibly just injector #5. Could it be #5 warming up? Maybe a dodgy fuel filter, it is an aftermarket, thought i order Mahle This one is getting my head scratching. Any ideas are helpful.... Thank you |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 79 ![]() ![]() ![]() |
Mine does the thumping noise when it's cold too.
Thank you for your responses!
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 266 ![]() ![]() |
next time it does it, put your ear to the air intake and you can possibly also listen to exhaust note.
Mine had a heavy 'thump' that started just after an oil change and would last 10 or so seconds after startup and then disappear. it has since gone away. Best explanation was a sticking valve, it was very clearly audible through the air intake. This was a very different sound than the one they make when the 5th cylinder knocks a little on a very very cold day. 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
yes, I thought something was up with one of the valves because this started with outside temps being 25+ degrees so far from a cold start. The glow plugs activating also will give you an understanding if it will be a cold start which they have not turned on this season.
I'll try and find a conditioner to add before my next oil change to see if I can unstick this but seems to slowly go away...... Thank you for the response! Since you have the same local stores then me what flush would you recommend? its not worth removing the head and freeing it up. Have you tried "Hot Shot Stiction" ? Seems like proper stuff with testing from Shell and ASTM Testing |
I havent done any kind of flush, not really a believer.
Id be tempted to do some more regular oil changes for a while and see how it goes. 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
yeah, i did this, the stiction is an oil additive not a flush
I agree, do not like flushes but never tried an oil additive...... |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
Check your manifold for broken bolts or warping. Kinda sounds like that to me. Your heat shield looks loose as well. Good luck. 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thought about that but I sprayed some soapy water on it and go not bubbles and I have since fastened the heat shield bolts. I couldn't find the support bracket that mounts to the exhaust
