![]() | Home > Td5 > Td5 Startup Thumping Noise |
DefenderCan Member Since: 25 Nov 2023 Location: Canada Posts: 7 ![]() ![]() ![]() |
Good morning All,
My first post..... Was hoping for some help on a noise I have on startup. When I start my truck up, I get a somewhat thumping noise that will last about 20 seconds max then stops instantly. If I drive without letting the noise stop it turns into a tick but stops after a few feet of driving. It will never come back throughout the drive. It doesn't thump all the time, never when hot. The noise matches the revs when accelerating. I am really tempted to pull the injectors and renew the seals and washers, but I have no solid evidence those are the culprit. Here is a link to the startup noise and you can hear it stop, https://youtube.com/shorts/mIzpUjs0Ml4?feature=shared If i don't let the noise stop, and drive a bit it will turn into a tick, in this video it is hard to hear, https://youtube.com/shorts/xL946srOG78?si=yd-eMZ7PFr6bd0pY So, this is my diagnostics so far, No smoke from exhaust, all plugs are dry, truck has 175,000km, oil level hasn't risen, coolant reservoir has no oil. I have dumped fuel additives with no help, and I run shell diesel and no blowby. It isn't too concerning as the truck runs fine, feels strong and I don't have any really concerning symptoms only the noises I hear. I am thinking possibly a burnt valve seal or possibly just injector #5. Could it be #5 warming up? Maybe a dodgy fuel filter, it is an aftermarket, thought i order Mahle This one is getting my head scratching. Any ideas are helpful.... Thank you |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 76 ![]() ![]() ![]() |
Mine does the thumping noise when it's cold too.
Thank you for your responses!
