Home > In Car Electronics > Footwell and dash tray lighting
Scottyboy
Germany 1999 Defender 110 Td5 SW Chawton White
1999 Td5 110 CSW
The interior is so dark at night. I would like to install blue lighting for the dashboard tray and for the front footwells. I have looked at a lot of options online, but I can’t find lighting that’s bright enough to illuminate, yet dim enough to not interfere with night vision.
Any suggestions are welcome.
Post #1075128 9th Sep 2025 5:45pm
rustandoil
Chap I know showed me some LED "noen" strip.... Very impressive 😎
I think it came from Ali Express
Post #1075130 9th Sep 2025 6:05pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Some footwell lighting on Roy5695's Build Thread using LEDs from a strip
https://www.defender2.net/forum/topic30623-45.html Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1075149 9th Sep 2025 8:47pm
Scottyboy
Thank you! I sent him a PM.
Post #1075157 10th Sep 2025 5:30am
el sid
England 1996 Defender 90 300 Tdi CSW Barolo Black
i tried some led strips but they got too hot for my liking.I dont know if thats normal or not.
Post #1075344 13th Sep 2025 8:58pm
30cm 5050 LED strip, just above the footwell on the lowest edge of the dash.
I found the adhesive would often let go, and come off, but, I put sellotape over and, around the rear lip and that keeps it in place long term.
You can even wire into the interior light system, just be aware of the current consumption, you want any load above 1A, realistically for the length you’ll be well below that.
You can use an ignition switched supply elsewhere of course if you wanted to.
On mine I can have OFF/ ON Interior inc dimming / Permanent ON.
That mirrors the interior light, the dimming can be a bit more steep of a cut off due to lower current but still works perfectly.
If you have a rear interior light, you have another upto 1A supply there too.
1A is a lot for LED’s.
There is RGB types with a controller but these will pull more power, I used a single colour strip.
I seem to remember each 30cm strip would be about 180mA in current each, approx. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1075352 13th Sep 2025 10:28pm
Scottyboy
Good to know. Thank you for all the information.
Post #1075361 14th Sep 2025 7:13am
