![]() | Home > In Car Electronics > Footwell and dash tray lighting |
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
Chap I know showed me some LED "noen" strip.... Very impressive 😎
I think it came from Ali Express |
| Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 256
Some footwell lighting on Roy5695's Build Thread using LEDs from a strip
https://www.defender2.net/forum/topic30623-45.html Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
| Scottyboy Member Since: 09 Jul 2024 Location: Kaiserslautern Posts: 20
Thank you! I sent him a PM.
| el sid Member Since: 06 Sep 2025 Location: devon Posts: 22
i tried some led strips but they got too hot for my liking.I dont know if thats normal or not. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21028
30cm 5050 LED strip, just above the footwell on the lowest edge of the dash.
I found the adhesive would often let go, and come off, but, I put sellotape over and, around the rear lip and that keeps it in place long term. You can even wire into the interior light system, just be aware of the current consumption, you want any load above 1A, realistically for the length you’ll be well below that. You can use an ignition switched supply elsewhere of course if you wanted to. On mine I can have OFF/ ON Interior inc dimming / Permanent ON. That mirrors the interior light, the dimming can be a bit more steep of a cut off due to lower current but still works perfectly. If you have a rear interior light, you have another upto 1A supply there too. 1A is a lot for LED’s. There is RGB types with a controller but these will pull more power, I used a single colour strip. I seem to remember each 30cm strip would be about 180mA in current each, approx. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Good to know. Thank you for all the information.
