Home > General & Technical (L663) > How good is the Alternator? Ecoflow Alternator Charger
HardTopRog
Hello.
I have an Ecoflow Delta 2 battery generator, which usually comes around with me in my current vehicle.
I'm waiting on the arrival of a D250 Defender Hard Top.
I'm looking into the Ecoflow Alternator to charge my Delta battery on the go.
Here is the product:
https://eu.ecoflow.com/products/800w-alternator-charger
In short, you attach the "Alternator Charger" to the battery terminals, and when the voltage of a running car kicks in, the Delta is charged using up to 800W via the car's alternator.
You can set it to turn off when the voltage reduces, thus not draining the car battery when ignition is turned off.
You can also reverse charge, so the Delta battery can top up the charge of the car's battery.
My question to anyone in the know:
How much resolve does the Defender D250 alternator have, can it handle the extra load?*
*The Alternator Charger can demand up to 74A draw from the alternator when it full whack (I believe this can be throttled, or the smaller 500w version can be used instead if the Defender Alternator can't handle it)
*Ecoflow states an alternator of above 150A is best suited to the alternator charger. Quick research suggests an A output rating is not quite so simple on the Defender alternator (I am about to deep dive, but if anyone can explain it's unique system in lamen terms, it could save me some time).
Thanks,
Post #1075033 8th Sep 2025 1:58pm
TexasRover
I suppose that depends on any other loads, because you will be using the spare generating capacity to charge your EcoFlow. All might be fine till you switch on the heated seats, windscreen, headlights etc.
As the load builds to a maximum, eventually the voltage will start dropping. Maybe your Alternator Charger devise will cut back on the amp draw if it detects it is pulling too much. There seems to be a fair bit of cleverness build into that box, maybe see if you can get hold of a technical data sheet.
Edit: In fact thinking about it, there must be a charge limitation because when your engine is idling the alternator will never provide full Amps. I doubt anyone will think it's a good idea to pull 75A on a cold morning when the engine just fired up..
Post #1075035 8th Sep 2025 2:40pm
kenl
Australia
Is the car you are buying a mild hybrid? They work differently.
If the charge voltage is the same as a 12v battery then you can use a normal DC|DC converter such as the Victron Orion XS.
It can have its current output adjusted with an app.
https://www.victronenergy.com/dc-dc-conver...y-chargers MY23.5 SE Defender
Post #1075072 8th Sep 2025 11:24pm
radim.strnad
Czech Republic
yes, all new D250 are mild hybrid engines with 48V architecture
Post #1075087 9th Sep 2025 9:20am
kenl
Australia
I have asked about the output of the 48 to 12v converter that the car haa nad have been told 12v @ 170amps.
I don't know if this correct, but the guy seemed to know his stuff. MY23.5 SE Defender
Post #1075093 9th Sep 2025 10:34am
