![]() | Home > General & Technical (L663) > How good is the Alternator? Ecoflow Alternator Charger |
| HardTopRog Member Since: 13 Aug 2025 Location: Bristol Posts: 7
Hello.
I have an Ecoflow Delta 2 battery generator, which usually comes around with me in my current vehicle. I'm waiting on the arrival of a D250 Defender Hard Top. I'm looking into the Ecoflow Alternator to charge my Delta battery on the go. Here is the product: https://eu.ecoflow.com/products/800w-alternator-charger In short, you attach the "Alternator Charger" to the battery terminals, and when the voltage of a running car kicks in, the Delta is charged using up to 800W via the car's alternator. You can set it to turn off when the voltage reduces, thus not draining the car battery when ignition is turned off. You can also reverse charge, so the Delta battery can top up the charge of the car's battery. My question to anyone in the know: How much resolve does the Defender D250 alternator have, can it handle the extra load?* *The Alternator Charger can demand up to 74A draw from the alternator when it full whack (I believe this can be throttled, or the smaller 500w version can be used instead if the Defender Alternator can't handle it) *Ecoflow states an alternator of above 150A is best suited to the alternator charger. Quick research suggests an A output rating is not quite so simple on the Defender alternator (I am about to deep dive, but if anyone can explain it's unique system in lamen terms, it could save me some time). Thanks, |
| kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 34
Is the car you are buying a mild hybrid? They work differently.
If the charge voltage is the same as a 12v battery then you can use a normal DC|DC converter such as the Victron Orion XS. It can have its current output adjusted with an app. https://www.victronenergy.com/dc-dc-conver...y-chargers MY23.5 SE Defender |
| radim.strnad Member Since: 05 Sep 2025 Location: Prague Posts: 3
yes, all new D250 are mild hybrid engines with 48V architecture
I have asked about the output of the 48 to 12v converter that the car haa nad have been told 12v @ 170amps.
I don't know if this correct, but the guy seemed to know his stuff. MY23.5 SE Defender |
